Old 16-02-2011, 05:44 PM   #1
ic0nic
Default Idle problems solved! Thank you!
Just wanted to say thank you to all of those that posted on these forums in relation to idle issues. I just spend all of four hours replacing my inlet manifold gasket and this solved the problem!
Thank you!
ic0nic is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2011, 06:44 PM   #2
sly
Sly like a G6
sly's Avatar
Yep, it'll do the trick. Apparently it's common for the gasket to leak around cyls 1 & 2, but mine was leaking at the back, around 5 &6.
Now I have a sweet, smooth idle down to 600rpm that is only belied by some slight whine from the blower :-)
Sleeper, anyone?
Old 16-02-2011, 07:01 PM   #3
Good news.
