5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
Hi all.
I thought that I would write up today's activities as a supplement to the removal of rear hubs as prepared by russellw in the tech resources section. This applies to AU2/3 IRS. In this example, I removed both half shafts to facilitate the replacement of my rear swaybar. Article relocated to Tech Portal
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
Just another mock-up..
Well done mate..!
Great write up..!
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
All Bran = Regular Member
Well done and thanks!
I may be replicating before too long :( |
I fitted the same bar to my TE50. Can't remember exactly what I did to get it in - can remember it was struggle and son-in-law was helping - but didn't remove driveshafts that's for sure. We had the car jacked high.
Anyway, nice job of documenting how to remove the driveshafts. Going that far I would have replaced the bearings as they are a known problem
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
#5 | |||
5.6L x 2 pilot
My bearings are ok (touch wood) at the moment so it can wait, not that I have the kit to separate hub! Cheers to all the compliments Thanks, Stu.
Can you just drop the diff to get it out? To replace the swaybar that is?
#7 | |||
5.6L x 2 pilot
Always keen to hear of better ways. If you come up with a better way, please let us know. Cheers Stu
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
Well done Stu
UK
Many, many thanks to AU11LTD, I'm old school and used to pulling axel out and smashing bearing off with a hammer and rag and press it all back on. Also thanks to Macka for pointing me in the right direction to the info WITH pictures. Thank you again men!!
Hi guys, I've removed the rear disc assembly so that I can change out the hub & bearing on my AU 2 XR8 and can not get the hub and backing plate apart from each other. I am at a bit of a loss, I seen a video on the front hub & that had a circlip at the back of the bearing but no such thing on the rear, not that I can see. Any suggestions PLEASE. George
I have sent a PM to auIILTD so that when he comes on he will come here and give you some help
Sorry but I have never had to do one of these so I don't know. Hang in there
2 users like this post: |
#12 | ||||
5.6L x 2 pilot
George, they will need to be pressed apart. On the inner side is a circlip that has to be removed and then you can actually press the hub out. Good luck. My mate and I used a 6T press with mixed results. Luckily the one we needed separated worked well, but getting the hub out of another (provided by Shayne btw), we were not so successful. We could get the hub out, but not the bearing. Here is a pic of the inner after I experienced a failure (you can see the circlip). Inner hub presses out from this side, bearing presses out from the outer side (once circlip removed). ![]() Hope that helps. Quote:
Cheers Stu
Thanks to both of you!!! So there is a circlip behind the bearing!! The videos I've seen didn't show a clip except on the front. I should be able to move forward now! Thank you again. George
#14 | ||
5.6L x 2 pilot
Circlip is on the inner side George (axle side). The bearing is then pressed out from the outside.
Cheers Stu
