Old 14-06-2011, 07:12 PM   #1
Pis-ton broke
Pis-ton broke's Avatar
Default USA cordless tools on Australia 240v power?
I,m thinking about buying a De walt cordless combo kit from the USA. However De walt tools in USA are 110 volts (the charger ), question is, has anybody brought USA power goods and run it on 240v? do i need a step down transformer for the USA stuff?,or just get a plug adapter?
cheers Mick
Pis-ton broke is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2011, 07:21 PM   #2
opto
Default Re: USA cordless tools on Australia 240v power?
Why dont you get a 240 volt Charger from Dewalt Australia, problem solved
Originally Posted by XCPWSF
Is there portable speed cameras? Because coming home from school I noticed a cop sitting on the corner, with some box with buttons and knobs, with wires running into one of the big gum trees.
Just practicing with the Tazer on a Koala?
opto is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2011, 07:41 PM   #3
Benjamin Smith
Benjamin Smith's Avatar
plus if anything goes wrong with it you will not will be able to get warrenty work done if something goes wrong. and just a quick question what is the kit code and price you paid if you don't mind.
Benjamin Smith is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2011, 07:59 PM   #4
Pis-ton broke
code is DCK675L for $657.00 6 piece lith- ion battery
opto, thats a good point , but will the Ozzy charger be compartible with the Yank battery?
Old 14-06-2011, 08:00 PM   #5
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Hey Mick,
Email the seller and ask for the voltage range of the charger. Most stuff these days works between 100-240v anyway to cater for all the variable voltages around the world.
So, all you may need is the plug convertor.
Old 14-06-2011, 08:15 PM   #6
Jim Goose
Silly question but why buy a drill from the USA? Surely by the time you pay for freight it will cost the same as the aussie price?
In anycase most chargers operate of a range of voltages.
As long as the input voltage and charge rate is the same it wont matter.
The other issue is warranty....
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2011, 08:25 PM   #7
Pis-ton broke
thank yellow festiva.
Mr goose, its a combo set. in Australia its worth over $1500. to let you know, yank stuff is heaps, heaps cheaper, and the dollar is good. Its new , a big well known company, and i,ve brought stuff from Toolking before. shipping is about $180.
Old 14-06-2011, 08:28 PM   #8
Tomo1972
I had two 18V Dewalt cordless drills arrive today....landed for $240 total.
Retail in Oz is $375 each.
Impact driver last week $120 landed...In Oz is $320
Batteries 4 weeks ago for $65 each.. in Oz $110
Cant beat US prices at the moment.
Tomo1972 is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2011, 08:34 PM   #9
Scott
Originally Posted by Yellow_Festiva
Hey Mick,
If they don't suit (some I have googled seem to be 120v only), you can get Step Down Transformers (240->120v) from jaycar/ebay pretty cheaply and they already have the appropriate plug/s. Bit of a fiddly way to do it though.
Scott is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2011, 08:35 PM   #10
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Interesting thread as I am also looking at a Makita Rotary polisher from the states aswell and have to find out how the different volt's etc work.
Old 14-06-2011, 08:37 PM   #11
shedcoupe
Apart from the voltage issue, US electrical system is 60 Hz and Aussie is 50 Hz (frequency).
This may or may not be an issue for the charger's electronics.
The batteries are likely to be the same in US and Aus tools.
Trivia - my understanding is that a motor designed for 60 Hz will run slower on 50 Hz, and a motor designed for 220 V will have more torque on 240 V. Not related to this subject of course, as the motor in a cordless drill is DC, but this may be of interest to those thinking of bringing in corded tools that may be 220 V (though more likely to be 110 V and will need a step-down transformer).
shedcoupe is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2011, 08:42 PM   #12
Yellow_Festiva
Where to next??
Doubt it will be an issue. I just looked at my laptop charger.
Input "100-240v and 50-60Hz"
It also has a clever system where the box of the charger (incorporated into the plug) has a removable AU pin socket. Twist it off and another plug can be slotted in.
So, they must use the exact same charging / battery hardware for all markets.
Doubt the drill would be any different.
Old 14-06-2011, 08:51 PM   #13
shedcoupe
Agree. The electronics in the charger are unlikely to be affected by the frequency difference, but if the charger voltage does matter it will need a step-down transformer.
Old 14-06-2011, 08:54 PM   #14
Pis-ton broke
thanks scott, i didn,t know that, if worst comes to worst, i will go to jaycar. it with be a done deal, i,m buy,in it, hear come my new toys.
Old 14-06-2011, 09:14 PM   #15
AUIIPURSUIT
pursuit ute baby
AUIIPURSUIT's Avatar
i bought a 36V dewalt kit from the states a few years back.
the charger requires a step down transformer. You CANNOT just go buy the cheapest available. It HAS to have suitable amperage or it will just FAIL miserably. So you are looking around the 100$+ mark for a step down that is no frills and will do the job properly.
Its also a pain in the **** if u need to take a step down and a bulky charger on site (i leave it at home and if they die, they die). So buying a charger locally is probably a better solution. They are quite expensive though, even extra batteries are a junkload pending what voltage youre looking at.
Secondly, we had 2 batteries die within a week and they are basically bricks now. they arent worth returning and dewalt aus wouldnt have a bar of it.
FWIW, i think dewalt tools have gone down the gurgler and theres much better brands around.
Considering its tax deductable anyway (guessing your a tradie too), look around before you bite the bullet.
best of luck from someone whose been there.
my ride : AU xr8 pursuit ute
AUIIPURSUIT is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2011, 09:25 PM   #16
Pis-ton broke
what sort of good brands are you talking about AUIIPURSUIT. Makita? or Hitachi?
I have heard that about de walt too. but i don,t have much time to check every tool spec. de walt has a steel gearbox in the drill.
Old 14-06-2011, 09:25 PM   #17
shedcoupe
The cost in making a cordless tool is mostly the battery these days as motors, gearboxes, chucks, chargers etc. just aren't that dear now, so the tale of the dead batteries above is very relevant - if a battery dies early it is expensive to replace without warranty backup.
Old 14-06-2011, 09:30 PM   #18
Yellow_Festiva
Where to next??
I guess that's the risk you take when buying these items from OS. I bought a laptop battery online and it has died within 2 months. I'm debating if it is worth paying $25 to send an $85 battery back for their 'assesssment of the failure'.
Not that I do it often, but I will prob not buy something like this again from OS. I wonder if they send dodgy / 'factory seconds' to us because they know most won't bother sending it back...
And if they send another replacement battery, it will prob come straight out of the same batch the first one came from..
Old 14-06-2011, 10:12 PM   #19
AUIIPURSUIT
pursuit ute baby
panasonic make awesome impact drills, theres a reason nearly every chippy uses them.
Im also a fan of milwaukee gear in the cordless range and of course the makita li-ion is pretty good kit.
Old 14-06-2011, 10:21 PM   #20
Giant Cranium
VF2 SSV WAGON
Giant Cranium's Avatar
im hitachi thru and thru. have had the whole cordless range for the last 3 years and treated them badly and they just keep going.
even the batteries have not fadded with over 1000 charges on each of my 6 batteries
also milwalkie are good but to big and heavy
Giant Cranium is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2011, 05:14 AM   #21
sudszy
Most stuff exported to Australia will be as you describe above and for laptops/phones where the market is world wide it makes sense to just send the one charger off everywhere, especially since people travelling with these items is common these days.
For a product that is made in the USA, they are unlikely to add expense to the local product by having the charger work at dual voltage/frequency, the cost would be considerable especially if it is a high current/power device for charging drill batteries, rather than just a mobile phone charger.
Possibly one thing I would consider is contacting the supplier where you(OP) intend purchasing the unit and ask whether they can organise a 240V charger through de Walt USA at their end.
sudszy is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2011, 11:55 AM   #22
CJR09
RPO 77
CJR09's Avatar
^^^^this^^^^
been there done it also - I'm with makita now - li-ion
not quite as good as the milwaukee but similar warranty and half the price
bang for buck makita is where its at
Q: If you have tried to sell it three times now and it is still not sold, do you think it might be over-priced?
A: It is over priced - just like all the other falcon coupes for sale!!
CJR09 is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2011, 01:58 PM   #23
XESP351
XESP351's Avatar
Couple of months ago I bought a Hitachi combo kit which included Circ Saw, angle grinder, jigsaw, two Li-Ion batteries and charger, plus a Hitachi bag for $650 from an Aussie seller on Ebay who imports them from USA and has the correct voltage, frequency and plug for Oz. I rang Hitachi Oz and this same kit would have cost $1320 with 12 months warranty. The seller was a very good bloke (picked it up from the warehouse) and provides replacement warranty for 12 months, the tools have performed flawlessly so far. He also sells Milwaukee and Dewalt gear.
Let me know if you want his details and I'll see if i can dig them up.
XESP351 is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2011, 03:23 PM   #24
Charliewool
Bolt Nerd
Charliewool's Avatar
Dewalt aren't a patch on what they once were!.. My opinion, This.. http://www.fordforums.com.au/showpos...47&postcount=5
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4
Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD
Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD
2 wheels.. 2015 103ci HD Wideglide.. SOLD
SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida!
(Ex Blood Orange #023 FPV Pursuit owner : )
Charliewool is online now   Reply With Quote Multi-Quote with this Post
Old 15-06-2011, 03:28 PM   #25
Tomo1972
I cant fault Dewalt. Mine cop a thrashing everyday and I havent had a single failure from....
2 x drill/driver/hammer drills
1 x rotary impact hammer drill
1 x impact driver
1 x angle grinder
1 x recip saw
1 x torch
1 x fluro light
1 x wet vac
1 x radio/charger
All of the above are 18v cordless and three years old
The only failure I have had is one battery in three years.
Just purchased a spare drill/driver, impact driver and 6 batteries....to kill some tax.
Old 15-06-2011, 10:30 PM   #26
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
The cahrger will most likely only work at 110v. They do this so you buy the overpriced item in Oz (the cost to make a 110-240v SMPS is no real cost difference).
But as said you can go down to Jaycar and get a step-down transformer. This will cost you around the $200 mark from experience.
Daniel
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2011, 10:43 PM   #27
sudszy
http://www.tortech.com.au/product/250-watts-step-down/
it implies the 50Hz output isnt a problem for the dewalt chargers.
Old 15-06-2011, 10:46 PM   #28
Barnaby
Barnaby's Avatar
I used to work next to the DeWalt service agent in Melbourne (Chirnside Park) and their big clean-away bin was chockers in about a week! Guys there said they had lost the plot and that they all seem to do it - build a rep and then blow it by cutting corners on new models and then battle for a few years to get their rep back and then do it all over again. Milwaukee is a good example, had a good reputation for a few years but the new ones are having issues according to a mate who sells them.
Panasonic are good but there is only one that never seems to have issues - Hilti $$$
http://www.hilti.com.au
The frequency of the mains wont be an issue for the newer switching supplies, the old transformer/linear supplies sometimes could overheat over longer periods.
Barnaby is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2011, 11:00 PM   #29
homegrown
hotshot
homegrown's Avatar
HI Ya I bought a KIT OFF EBAY It was a 7 piece set save hundreds buying it from the states. No issues with the tools. Batteries are fine, Charger has a step down, but with the money I saved I could easily buy a new Aussie one and still have saved heaps. 60 50 hz is no issue., All the tools are made in China and half of China is 50 hz while the other half is 60.
Just thought Id write my thoughts. Tools are great quality and I trash the crap out of them on a daily basis
Try Total Performance for a change!! Ford.
homegrown is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2011, 11:03 PM   #30
ea90gl
ea90gl's Avatar
My vote goes to milwaukee, used plenty of others and yes they may be bigger and heavier but the power/torque the 18V range gives out is brilliant. Got the 6 piece set almost a year back now and do not regret it. Looked at sets from the US but as mentioned since tools are us tradies bread maker it's not worth risking warranty and having to send it back and wait etc. Just purchase here the extra you pay is well worth it.By the way Milwaukee offer 5 years warranty on tools/2 years on battries
ea90gl is offline   Reply With Quote Multi-Quote with this Post
