Old 14-09-2011, 08:15 PM   #1
BHDOGS
Default Charcoal canister ticking
My car has a ticking from passenger front near airbox I'm assuming it's the canister I'm gonna wrap it in something like bubble wrap but have no idea wat it looks like a pic would be handy if anybodys up for it!
Old 15-09-2011, 03:35 PM   #2
BHDOGS
Default Re: Charcoal canister ticking
ok no pics then how bout a description of what it looks like then and an exact location im removing front bar so should be able to see it easily?
Old 15-09-2011, 04:04 PM   #3
FPV+fteT3
Performance Inc.
FPV+fteT3's Avatar
Probably easier to remove the inner plastic on the LHS guard the thing that clicks should be accesable there it is a small box about guard height/bar height mine is factory fixed using some foam rubber cable tied around the unit this was the ford fix in 02 seems to work ok though.
In The Garage...
FPV Super Pursuit Build no 0080/91
Lotus Exige S/C S240
Kart Hasse Chassis 100J Power
Originally Posted by flappist
Rental cars, the equipment of choice to get to destinations where 4WDs fear to drive......
FPV+fteT3 is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2011, 02:40 AM   #4
BHDOGS
thanks for that
Old 23-09-2011, 10:16 AM   #5
GCPursuitPower
AUII XR8
GCPursuitPower's Avatar
Is there any way you can remove these canisters without any issues to the car?
Ford XR8 AUII Sedan, 5.6L Stroker Engine 250kw.
GCPursuitPower is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2011, 11:18 AM   #6
james22
With da Warlords
james22's Avatar
Not to keep it emissions compliant. If you removed it it would get preety smelly too. Fuel vapour.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 23-09-2011, 08:43 PM   #7
It will be the CANP (canister purge) valve opening and closing, It usually happens when the hoses are moved so the valve touches the chassis rather than be suspended in the air by the connecting hoses. Otherwise the valve is faulty. Follow the hoses from the canister and you will find the valve as it has two wires connected to it. You can confirm it's the valve by temporarily disconnecting it from the wiring harness.
