Old 19-09-2011, 05:03 PM   #1
parker
Default Is oil getting to valves rocker cover?
I just did the head gasket on my AUII egas. The top end is noisey since even though the guy who checked my head said it was fine...
It's hard to tell if there is adequate oil getting up there, so I've only let it run a few minutes since starting it and hearing the noise.
Is there a good way to be sure of that? If I have the filler cap off, should I be seeing oil splashing around in there somehow? How much oil is pushed up there, and how does it get up there?
Thanks
parker is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2011, 05:07 PM   #2
Mechan1k
Mechan1k's Avatar
Default Re: Is oil getting to valves rocker cover?
Is it making a clacking sound ... You may have a clogged lifter.
Is the idle a little on a rough side????
Old 19-09-2011, 05:17 PM   #3
parker
Seems to idle smoothly, but it does sound a little tractor-like... great description hey!
Old 19-09-2011, 05:50 PM   #4
FGII-XR6
FGII-XR6's Avatar
start it briefly with the rocker cover off you should see plenty of oil if all is well. what oil are you using? if you use oil that is too heavy you will get noisy lifters. the AU is quite sensitive to this and I use 5 W 30 to keep the lifters quiet even 10 W 40 gives a bit of lifter noise
[SIGPIC][/SIGPIC]
Rides:
Old 19-09-2011, 05:53 PM   #5
Mechan1k
Mechan1k's Avatar
AUII EGAS was 15W40 from factory ... never had an issue with noisy lifters either ... even with a reground cam and shimmed lifters.
They can get gummy deposits in them though.
I'd give it a bit of time to settle down ... as it is has all just been pulled apart and put back together.
Old 19-09-2011, 05:58 PM   #6
FGII-XR6
FGII-XR6's Avatar
genuine factory workshop manual says 10 W 30
[SIGPIC][/SIGPIC]
Rides:
Old 19-09-2011, 06:02 PM   #7
Mechan1k
Mechan1k's Avatar
Interesting ... owners manual and Oil cap on engine stated 15W40
I know the petrol ones were 10W30.
Old 19-09-2011, 06:14 PM   #8
FGII-XR6
FGII-XR6's Avatar
I think they updated it due to noisy lifters, I have seen them with both caps in Egas cabs. the factory manual says all 6cyl use the same oil now. just like ford to cause confusion
[SIGPIC][/SIGPIC]
Rides:
Old 19-09-2011, 06:15 PM   #9
Mechan1k
Mechan1k's Avatar
Hahahahaha ... I wouldn't be surprised.
Old 19-09-2011, 08:38 PM   #10
Day-mow
rexnet
Day-mow's Avatar
maybe try a lifter addative.
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 19-09-2011, 08:49 PM   #11
falconhell74
falconhell74's Avatar
did the timing chain tensioner get set correctly when head replaced ? if not & too tight it will sound like a tractor till you stuff the oilpump drive or tensioner race, or in my case a long time ago seize the oilpump drive in the block
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2011, 09:24 PM   #12
parker
I just replaced the oil. I had to anyway cause the first lot was clearing out the 'milk'. The first oil I put in was a bit thicker, but this thinner stuff has made no difference.
As I went for a little drive it dawned on me that the sound I was hearing was exactly the same as when I discovered the milky stuff in the first instance...
I'm not sure what to think now. I really don't know much about shafts going on in the head other than the inlet and exhaust valves opening and closing.
I'll read up on what a lifter is.
The noise is at the rear, so its not the timing chain itself, but I was a bit iffy about that tensioner mechanism.
Old 20-09-2011, 03:57 PM   #13
parker
Added 'lifter free' and the noise was gone within 5 mins!
THANKS all.
Old 21-09-2011, 10:52 AM   #14
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
I'm pretty sure au3xr6 is right - the original egassers came out with 15w40 caps then went to 10w30 caps
10w30 is way too thin for an egas - in sunny qld anyway.
Old 22-09-2011, 10:00 AM   #15
FGII-XR6
FGII-XR6's Avatar
I'm running 5W30 in my dual fuel XR6 and it is fine any heavier and I get lifter tick ( engine only about 120 000 Ks)
[SIGPIC][/SIGPIC]
Rides:
