Old 28-09-2011, 06:10 PM   #1
needaXYGT
AU II XR8
needaXYGT's Avatar
Default AU II XR8 engine issue?
http://fordforums.com.au/showthread.php?t=11343961
In response the above thread, can someone list the possible and most likely causes of my XR8 to run lean and ping under load around 3000-4000 rpm?
Obviously the engine isnt getting enough fuel. The air filter is new and BP or mobile 98 oct is alway used. Does anyone know what sort of readings the maf sensor should give?
AU XR8 II ute
XD FAIRMONT GHIA 302
XA FAIRMONT 302 TOPLOADER
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2011, 07:41 PM   #2
Day-mow
rexnet
Day-mow's Avatar
Default Re: AU II XR8 engine issue?
how many Km has it done? whats the fuel filter like. whats the o2 sensor like.
i dont know heaps about the XR8's but there's a few options for ya
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 28-09-2011, 08:19 PM   #3
Whoosha
AU DIE HARD
Whoosha's Avatar
Could be just a timing issue , get tune shop to run a diagnostic over it, it may just need some timing taken out of it
Originally Posted by Riksta
Old 28-09-2011, 08:39 PM   #4
crakrz
T3 TE50 Blueprint
Technical Contributor: For members who share their technical expertise. - Issue reason: Craig has shown and shared an outstanding amount of knowledge in the field of Tuning. Craig is only to happy to share with anyone that asks his knowledge on the EEC tuning system, in particularly in the use of Moates Quarterhorse and Binary Editor.
Fuel pressure would be the first check. Should be 39psi with vac disconnected and blocked off. What plugs do your run? Does the same problem exist only at that RPM or all the way to redline? Maf voltage will be just over 1v at idle to approx 4.5v flat out. Have you cleaned your Maf at all?
crakrz is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2011, 04:52 PM   #5
needaXYGT
AU II XR8
needaXYGT's Avatar
Its done 160,000km. I bought the car with 108,000km on the clock and havent changed a thing on the car yet (Apart from fluids etc.). However, i have just bought new plugs and O2 sensors and just waiting on some leads and coil packs. Will do the fuel filter at the same time. So theres a chance that the problem may have something to do with all of that.
Just curious though, what cost am i looking at to get a re-tune done?
AU XR8 II ute
