Old 30-09-2011, 01:59 PM   #1
raised by monkeys
raised by monkeys's Avatar
Default are the 220kw motor stock headers an upgrade from the 200kw motor stocks headers?
any thoughts/opinions?
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
FG MkII G6E Turbo built by Heinrichs Performance and Tuning
BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning
"Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger
raised by monkeys is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2011, 02:11 PM   #2
Day-mow
rexnet
Day-mow's Avatar
Default Re: are the 220kw motor stock headers an upgrade from the 200kw motor stocks headers?
i think both are restrictive for memory. see paul and get him to slap on some pacemaker's
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 30-09-2011, 05:39 PM   #3
Sox
RIP...
Sox's Avatar
I have a feeling they're the same.
In any case, short 4-1's like that are crap.
A decent set of tri-y's are best for all street use, brands like H&M, Advance, Hurricane, Genie, and Lukey, all make sets which have good tube size and length.
Oval Everywhere...
Old 30-09-2011, 08:58 PM   #4
raised by monkeys
I can pretty much get a set for the price of a smile so it was worth asking.
Yeah, when my house/bills stop hogging my cash flow allows me ill get paul to hook me up with some headers and CAI stuff too.
cheers
Shaun
Current
Previous
Old 01-10-2011, 12:31 PM   #5
Whoosha
AU DIE HARD
Whoosha's Avatar
These are stock 220 against stock T3 apart from the HP coating they are the same , you may be able to compare the 200s against the pictures
Originally Posted by Riksta
Old 01-10-2011, 07:50 PM   #6
Day-mow
rexnet
Day-mow's Avatar
are they pretty restrictive Whoosha? i dont know much but they kinda look like they all get put into 1 pretty quick.
Old 01-10-2011, 07:59 PM   #7
galaxy xr8
Giddy up.
galaxy xr8's Avatar
The 200 and 220 kw factory header's are the same, although I have seen one set from a 220 (susposedly) that was larger in the pipe exiting the cat then my old 200kw ones, but I have also seen other's from a 220kw that were the same diameter.
But in general they are identical, so if you are looking to get a gain going from 200kw to 220kw factory header's, quite simply you wont.
Old 01-10-2011, 08:03 PM   #8
galaxy xr8
Giddy up.
galaxy xr8's Avatar
For a factory style header they wern't to bad, obviously there are better out there in aftermarket, but they still wern't that bad flow wise.
Old 01-10-2011, 08:54 PM   #9
b2tf
not here much anymore
b2tf's Avatar
The factory ones are great headers if youre looking to make the car dull and boring.
2024 F150 XLT
Old 01-10-2011, 09:51 PM   #10
T3man
T3man's Avatar
Yep - my T3s are all dull and boring so it must be the factory headers doing it.
Old 01-10-2011, 10:06 PM   #11
Sox
RIP...
Sox's Avatar
Yes, they really are that bad.
The primary pipes are way to short, and they aren't tuned length.
They are used from factory because they're cheap to make, easy to install, and a little better than an old style cast log manifold.
A much longer primary pipe, and tuned lenght will improves things.
Good tri-y's will improve things even further.
Oval Everywhere...
Old 01-10-2011, 10:27 PM   #12
b2tf
b2tf's Avatar
yeah but 40 extra cubes helps overcome it!
2024 F150 XLT
Old 02-10-2011, 08:17 AM   #13
Sox
RIP...
Sox's Avatar
Have you got a spare set of these?
Oval Everywhere...
Old 02-10-2011, 01:55 PM   #14
Whoosha
AU DIE HARD
Whoosha's Avatar
Well with out getting into the pros and cons of it all if you have none then I would buy Pacey's or Diphilllipo's if you have a set of 220s sitting there I would use them,Thing is to Look at what your going to use your car for If its basically a streeter with a few trips down the track, I would go the cheap option , It comes down to bang for buck, Ford gear both on the AUs and BAs arnt that bad IMO. Its been a while since I was involved in a fair bit of the early testing with AU V8s, from memory the HP gain on the aftermarket headers was only minimal at best until you open the motors up a bit then they come into there own, especially the 4 into 1 stuff .
and sorry Sox the T3 set will probably end up on a XR8 Cortina
