Old 20-10-2011, 07:39 PM   #1
BZINGA
Powered by Ford
BZINGA's Avatar
Default Steering Wheel removal & fitting ?
Just wondering if anyone knows who does AU steering wheel removal & fitting in the Frankston area or surrounding areas .. i have 2 cars that need to be done.
Cheers Darren.
BZINGA is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2011, 07:58 PM   #2
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
Default Re: Steering Wheel removal & fitting ?
you can do it yourself.
disconnect the battery,
leave it for 5 mins or so.
then remove the 2 torx headed airbag retaing screws from the back of the wheel.
lift the airbag out a little, disconnect the wiring plug from the socket.
take the airbag away from the steering wheel and put to one side.
then you need a torx T50 bit to undo the wheel from the column,
leave the bolt in a few threads, and pull and wobble the steering wheel to release it from the column.
when it comes loose, remove the bolt and swap the new steering wheel on
and reverse the following procedure.
takes about 15mins all up to remove and then refit.
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2011, 08:08 PM   #3
b2tf
not here much anymore
b2tf's Avatar
As above - not difficult to do at all with the right tools.
2024 F150 XLT
Old 20-10-2011, 08:12 PM   #4
BZINGA
Powered by Ford
BZINGA's Avatar
Yeah i read how it's done in the how to do threads but i don't have that special torx T50 bit that's needed. I thought if someone close by could do it i'd take it to them ...
Old 20-10-2011, 09:03 PM   #5
T3man
T3man's Avatar
The T50 isn't your problem at all - dime a dozen you can get them anywhere. The problem is the 2 five pointed torx that retain the airbag ... very few places have them. My advice is that after you get someone to take them out for you trundle down to your local hardware joint and get some stock hex head jobbies to fit back in their place - next time you have to do the job a standard hex socket is all you'll need.
Old 20-10-2011, 09:07 PM   #6
b2tf
b2tf's Avatar
Fully agree with Jeff, ive gotten rid of the stupid bolts off my airbag.
I have the torx bit to get the airbag out too.
2024 F150 XLT
Old 20-10-2011, 09:09 PM   #7
my67xr
my67xr's Avatar
im pretty sure the small torx bit is a T25 ?
67 XR Fairmont
Old 20-10-2011, 09:12 PM   #8
GK
Walking with God
GK's Avatar
Wink Re: Steering Wheel removal & fitting ?
Here you go!
Changing Steering Wheel
http://www.fordforums.com.au/showpos...1&postcount=59
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 20-10-2011, 09:14 PM   #9
BZINGA
Powered by Ford
BZINGA's Avatar
Originally Posted by GK
Here you go!
Cheers,
GK
Yeah i read that, that's what i was referring to in my post.
Old 20-10-2011, 09:19 PM   #10
BZINGA
Powered by Ford
BZINGA's Avatar
Where do i get this 5 pointed torx bit ? ... This is why i'm asking who removes the wheel as i don't think i have the right bits to do the job.
Old 20-10-2011, 09:56 PM   #11
FGII-XR6
FGII-XR6's Avatar
look here http://www.fordforums.com.au/showthread.php?t=5431
[SIGPIC][/SIGPIC]
Rides:
Old 20-10-2011, 10:13 PM   #12
BZINGA
Powered by Ford
BZINGA's Avatar
Any of these do the job?
http://www.ebay.com.au/itm/Ry-Tools-...item23153a9306
http://www.ebay.com.au/itm/5-POINT-T...item45fdaca5c4
Old 20-10-2011, 10:49 PM   #13
blownv8au
Pro Street Au Ute
blownv8au's Avatar
When i changed mine i went down to the local ford dealer and grabbed a mechanic and asked him if he would undo the two air bag bolts no worries. Went home and undone the steering wheel with a allen key. Throw the 2 air bag torx bolts away and use different bolts. I've got torx bits now but allen keys will do to get the wheel off if you don't have them.
blownv8au is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2011, 10:54 PM   #14
BZINGA
Powered by Ford
BZINGA's Avatar
Yeah fair point .. i thought owning the actual bits would be better since i need to do 2 cars plus any other car in the future.
I just wanna know if either of those ebay links is what i need to do the job?
Old 21-10-2011, 07:26 AM   #15
b2tf
b2tf's Avatar
2nd one looks like it might.
2024 F150 XLT
Old 21-10-2011, 08:11 AM   #16
portokatsiki
second one will fit I ve thw same
portokatsiki is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2011, 05:50 PM   #17
BZINGA
Powered by Ford
BZINGA's Avatar
Bought a little kit like the ebay link today, has the right bits in it. Tool guy says he sells alot of these for the ford bit and knew what i was wanting which helped.
Autotools in Hallam - $19.95.
