Old 17-04-2012, 09:18 PM   #1
robertjp
Default installing AU2 and on booster on an AU1
Has anyone got a template which to put on the firewall to drill out the new 4 holes to mount the booster. Have tried but didn't get it quite right and have buggered the booster.
If there is anyone out there you are my only hope!
Robert
robertjp is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2012, 10:27 AM   #2
bartsau
bartsau's Avatar
Default Re: installing AU2 and on booster on an AU1
You could use a series 2/3 pedal box and take a template off that.
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2012, 06:55 PM   #3
robertjp
did that, thanks for the help. Did you do this conversion and have trouble with the booster hitting one of the bolts on the steering column.
Old 18-04-2012, 07:39 PM   #4
bartsau
bartsau's Avatar
No I haven't done this but I found out the difference when using a series 1 pedal box in a series 3 for my manual conversion. I ended up drilling the holes I need in the pedal box and it was all good I hope you can get around the bolt hitting the steering column.
Wagon Build
Toy Car Build
Old 19-04-2012, 12:11 PM   #5
robertjp
the bolt wasn't hitting the sterring column but the body of the brake booster. Just got it all together after all the mucking around. I just hope the way my brakes felt without changing the booster and master cylinder is not indicitave of this conversion, mine were downright dangerous. Thanks for help.
