as title says i just put msd's and ice 9 mm leads on my series 1 xr8 and whenn i hit 4000rpm the car brakes down and struggles and push higher in the rpm... any ideas
Seasoned Visitor
collapsed cats?
blocked fuel filter? Air filter? fuel pump starting to die. could be a number of things. have you swapped back to the original coils to test if the MSD's are faulty? Assuming it was running fine before. If you have only changed 2 things being coils and leads and it was fine before, one of those 2 things is not working properly. basic deduction. |
originals were snapping at the plug on one the them ... but ran alright ... dont have them on me atm to test tho ... ... wouldnt collapsed cats hinder the ability to reach 4000rpm comfortably ??? when my skyline dumped its cat it sruggled to my any power let alone high end power. i might be wrong and correct me if i am
brand new air filter also |
Broken plug ? Or faulty new lead ?
1998 AU VCT Ghia - Stock as a rock - Wifes car 1991 Toyota Soarer TT - 11.72 @ 116.7mph 2004 Ford Escape XLT V6 - Family Ride . |
not here much anymore
Put new plugs in it, if the plugs are worn the extra voltage from the MSD's can finish them off.
2024 F150 XLT
![]() Join Date: Dec 2004
New plugs & have you got the firing order correct?
T1 TE50 P01 |
