Old 26-05-2012, 08:05 PM   #1
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Thermo fan always on
I noticed today that my thermo fan is always on (even when the car is dead cold)
Anyone had this before?
UK
Old 26-05-2012, 08:15 PM   #2
Jason[98.EL]
Jason[98.EL]'s Avatar
Default Re: Thermo fan always on
if you have the windscreen demister on as in defrost the thermos will run all the time as it uses the aircon to do so
I went through the same thing with my el and after lots of research that is what i found out
hope that helps
Jason
[SIGPIC][/SIGPIC]
Old 26-05-2012, 08:19 PM   #3
Uncle_Ken
Uncle_Ken's Avatar
I'll check now
UK
Old 26-05-2012, 08:25 PM   #4
Uncle_Ken
Uncle_Ken's Avatar
hope that helps
Jason
Interesting. Just tried this. I turned on the car (engine cold). Turned on the demister, no chan ge, Turned on the fan and air con, it started. I turn the aircon off and the thermo is still running
UK
Old 26-05-2012, 08:34 PM   #5
Jason[98.EL]
what position was the switch that you select the place for your air to blow
Ie does it have something like a person seated and a bit that looks like a windscreen with like a wavy look to it in a half and half type look.
if so it will still use the aircon and that will be why the thermo fans will still run on the half and half setting
Jason
[SIGPIC][/SIGPIC]
Old 26-05-2012, 08:42 PM   #6
Uncle_Ken
Uncle_Ken's Avatar
Jason
just tested this. Turn on the engine (no aircon, no demister) and the fan does not come on. Turn on the fan only (no aircon) and the thermo fan stays off. (I moved the direction options to all settings)
Turn on the aircon the thermo kicks in straight away. Turn off the aircon and it keeps going (direction options in any position) I have to turn the engine off to stop the thermo fan
UK
Old 26-05-2012, 08:48 PM   #7
JC
JC's Avatar
UK
You have a sticky relay, and it appears to be only sticking once on......Replace the relay by using another in the relay block and see what happens then.
Ford Performance Club ACT
Old 26-05-2012, 08:49 PM   #8
Jason[98.EL]
sounds normal to me as the ecu thinks that it has to cool things down even though the car is still cold
I thought the same thing and had all the wiring tested then come to the conclusion that it is normal
Jason
[SIGPIC][/SIGPIC]
Old 26-05-2012, 08:50 PM   #9
Uncle_Ken
Uncle_Ken's Avatar
Might try this in the day light JC. I drove your old beast today, still going strong
UK
Old 26-05-2012, 08:52 PM   #10
Uncle_Ken
Uncle_Ken's Avatar
Thanks Jason
Will have a good look tomorrow in the daylight.
UK
Old 26-05-2012, 10:00 PM   #11
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
had a friends EL do the same
his was a sticky relay too, i had a spare one that fixed the problem
there is a block of 3 just infront of the airbox, pull the cap/cover off and there they are.
have the ign on, so the fan starts, then remove the relays one at a time.
the one that makes the fan stop is the faulty one.
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2012, 05:28 PM   #12
Uncle_Ken
Uncle_Ken's Avatar
Fan No 2.
How much for a relay from Ford??
UK
Old 27-05-2012, 06:09 PM   #13
my67xr
my67xr's Avatar
i think they are about $25 odd from ford
67 XR Fairmont
Old 05-06-2012, 03:33 PM   #14
Uncle_Ken
Uncle_Ken's Avatar
Arrrrhhh...
I got a new rely swaped it over and the fan is still coming on (even if I don't turn on the rear Demister or aircon)
Bugger
UK
Old 05-06-2012, 05:18 PM   #15
Maka
Au Falcon = Mr Reliable
Maka's Avatar
G'day Uncle Ken, can you put your dash in diagnostics mode? Just to see what temp the fans first come on- (once motor reaches 80 deg the fans activate on low speed), my fans come on if i put the a/c on and stay on if a/c turned off when cold too. Fans are designed to fail on On also.
Check this out for further info, might help.
http://www.fordaustraliaforums.com/f...6-Cooling-fans
cheers,Maka
Old 05-06-2012, 06:39 PM   #16
Herrod Motorsport
www.sctflashtuning.com
Herrod Motorsport's Avatar
If the car is an auto ,it had a faulty temp sensor in the trans
Australia's No1 Ford Enhancement Specialist
103 Northgate Drive
Thomastown
VIC 3074
Phone: 03 9464 5100
Fax: 03 9464 5166
Herrod Motorsport is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2012, 08:05 PM   #17
Uncle_Ken
Uncle_Ken's Avatar
It is an auto. Where is the sensor located?
UK
Old 05-06-2012, 08:56 PM   #18
Maka
Maka's Avatar
Auto transmission temp sensor, box out job aint it? Uncle Ken go for the easy, cheap fixes first or go get the ecu scanned for fault codes mate.
cheers,Maka
Old 05-06-2012, 09:10 PM   #19
Maka
Maka's Avatar
Uncle Ken, Just noticed youre running a ba induction tube- ive just purchased one my self and intend to uprate the stock snorkel my question is was it worth it? Bummometer notice anything? or did you have you're car tuned? It certainley looks better!
cheers,Maka
Old 05-06-2012, 09:23 PM   #20
Uncle_Ken
Uncle_Ken's Avatar
cheers,Maka
Yes it does look good. Bummometer is good. Since I installed it with the 'standard" LPG throttle mixer I have had no backfires and the AU seems to accelerate stonger. I had Joes tune my car a while ago but I didn't have the BA intake then. With a standard petrol system, runnignthat width from the box with a K&N filter I reckon it would be noticable. I have enjoyed driving the AU more since I have this set up and now run my Auto with the ECON button off.
UK
Old 06-06-2012, 11:29 AM   #21
Maka
Maka's Avatar
Cool, i like! Couple more bits & pieces and i'll install my set up.
Thanks to fellow AFF member sheluchin for looking after me purchasing my ba setup.
cheers,Maka
Old 11-06-2012, 07:55 AM   #22
Uncle_Ken
Uncle_Ken's Avatar
Picked up some relays from the wreakers, and all keep the fan 'on' and it turns 'off' when I pull out Fan 1 and/or 2
UK
Old 11-06-2012, 02:29 PM   #23
LXV139
Everything you have described above is completely normal operation.
LXV139 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2012, 10:17 PM   #24
Uncle_Ken
Uncle_Ken's Avatar
But the fan comes on when the engine is dead cold,no aircon or demister turned on.
UK
Old 11-06-2012, 10:30 PM   #25
Herrod Motorsport
Yes because the trans temp switch is faulty
103 Northgate Drive
Thomastown
VIC 3074
Phone: 03 9464 5100
Fax: 03 9464 5166
Old 11-06-2012, 10:46 PM   #26
mik
mik's Avatar
just an evil thought, if it turns out to be an expensive autobox out job is needed , perhaps rewiring the fans with an after market tempreture control unit? i`m thinking less than a 100 buks would get it done?
Old 13-06-2012, 08:19 AM   #27
Uncle_Ken
Uncle_Ken's Avatar
Had a quick look on ebay, there are some kits
http://www.ebay.com.au/sch/i.html?_k...item2570e53c89
UK
Old 13-06-2012, 10:03 PM   #28
mik
mik's Avatar
looks like a few good units there, i remember having a davies craig one many years ago, it came with the adjustable temperature switch,relays and the mercury filled copper doover (can`t remember the correct name....old age is a *****), it also came with a piece of rubber with a slot in it so you could slide the mercury filled bulb into the radiator hose , it worked well.
.....capillery .
here`s a davies craig one, i would think a 40 amp relay could do both but i would have 2 just to be sure, i found out as a young bloke with a warm 289 thermo fans draw a lot of power and can run for extended periods, over kill with wiring and relays is acceptable on these items ;).
http://www.daviescraig.com.au/Contro...4-details.aspx
my young brother had a sort of home made unit, he bought a temperature switch from jaycar, very small unit no bigger than a 5 cent piece with 2 terminals coming out of the top of it with a few different temperature`s available,
his was 180 f that you secure to a hot part of the engine,using solder,epoxy glue it or cut a hole in a bit of rubber hose then gently hose clamp it to the thermostat housing or some part you think would be ideal for a temperature reading, then some decent qaulity wire and a couple of relays, it worked ok , but you need to find a bit of the motor that warms up a little quicker as when we did it we found it came on a little higher in the temperature range before it switched on, a bit past half way, then once the fan started it would cool down to halfway no probs, but i think our positioning of the sender was a bit crappy, mind you all up it probably cost 20 buks with single relay/wire/sender.
jaycar also has kit adjustable fan controllers pretty cheap, not sure about these, less sure about my soldering/electrical skills , , probably ok, not being an electrical dude i sorta liked the fan controller unit from DC.
Old 14-06-2012, 09:09 AM   #29
Uncle_Ken
Uncle_Ken's Avatar
I'm going to look into it and have a think. Will chat with my 'car nut' mate down the road and see what I can find on the net. The Davies stuff looks good (I have an auto trans rad from them). There is some interesting stuff from the states as well. For me being a non sprakie is how to stop the reading from the broken sensor in the tranny and makeing the ECU/fan (is that right) look for the reading from the 'new' sensor.
UK
Old 14-06-2012, 04:07 PM   #30
mik
mik's Avatar
yes it would be good to make just work as it`s supposed to if possible.
