Old 04-07-2012, 02:03 AM   #1
fbvisitor
Default 2007 LT TDCI sump plug
A simple one for you blokes in the know.
What size allen key is the sump plug? None of mine fitted when I sussed the job out and I couldn't tell if the plug was perhaps slightly damaged or was an odd size.
Cheers.
fbvisitor is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2012, 09:28 AM   #2
marg99
Default Re: 2007 LT TDCI sump plug
Be most careful as I used the wrong size key and ended up buying a new sump plug. The fact that the dealer had them in stock tells you something I suspect the metal is a bit soft. I cannot recall the correct size now.
Old 04-07-2012, 09:17 PM   #3
rand0mn00b
interesting that the diesel needs an allan key to open the sump plug... petrol just needs a spanner
i wouldn't consider this anything odd. it is fairly common (good?) practice to replace washers and sump plugs every few changes
can't help you on the size either. but if you need to replace the sump plug, i would suggest getting a magnetic one so that any stray bits of metal coming off inside the engine and in your oil stick to it and can be removed at the next oil change. i'm surprised at times how much is floating around at changes!
rand0mn00b is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2012, 09:43 PM   #4
Russ
Russ's Avatar
Is it an Allen Key or a Torx head in the sump plug ? I would think they would at least have a Torx head plug for easier removal
Old 05-07-2012, 08:45 PM   #5
Turbodiesel
Torquer
Turbodiesel's Avatar
It's a size 8 allen key.
2007 LT Focus TDCi S
Bluefin Remap - K&N Apollo CAI - 2.5" Turbo-back Straight Pipe - 24mm Rear Sway bar - LT Zetec Bodykit - Black Projector Head Lights - LED Tail lights - DMB Overlays - Alloy Pedals - Scuff Plates - Sports Gear Knob - LV XR5 Springs - LV XR5 Wheels - Pirelli P-Zero Nero
Turbodiesel is offline   Reply With Quote Multi-Quote with this Post
