Old 08-07-2012, 11:59 PM   #1
david lee
Default rotors
when i bought my 2002 xr6 with 116000ks the ford dealer said the rotors had been machined due to vibrations under load the problem is still there braking down from 100kph should i replace the rotors or have them re machined thats if they were done in the first place thanks
david lee is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2012, 09:08 AM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: rotors
I would get new rotors
UK
Old 09-07-2012, 09:46 AM   #3
GK
Walking with God
GK's Avatar
Default Re: rotors
+1 for new rotors and pads.
There's a stack of debate and opinions on which combo's work best, but many here contend that a good combo would be either:
QFM Pads - One step above stock.
RDA Slotted rotors
DBA Sotted rotors
Stock and a little above normal driving situations will see the above recommendations serve you well.
There are many fans of either rotor (my choice is RDA) as I've had both and the QFM pads pull up well, with minimal dust and long life.
Others will advise you on different pad choices, often such recommendations are from members who drive on track days and such and their experience is valid, as I don't use either of my AUs on the track. Also, if you're opting for track work, you would probably go slotted and dimpled rotors instead of just slotted.
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 09-07-2012, 09:53 AM   #4
Uncle_Ken
Uncle_Ken's Avatar
Default Re: rotors
+ What GK said
UK
Old 09-07-2012, 12:14 PM   #5
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Re: rotors
With an AUII/AUIII I wouldn't bother with slotted rotors - new normal ventilated units with good QFM pads will provide you with pretty good feel. I find that slotteds chew through the pads too quickly and dust up too much for the small (to none) benefit provided in regular driving. But yes I would very much recommend that you replace your rotors if they've already been machined once.
Old 09-07-2012, 12:25 PM   #6
ford_mytoy
Default Re: rotors
Get new rotors and pads. I have recently got my brakes changed and I am very happy with them. Braking is smooth even at high speeds and braking distance has significantly improved. I am using RDA Slotted Rotors and Bendix Heavy Duty Pads.
Paid $400 all up for the parts
ford_mytoy is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2012, 04:59 PM   #7
blueoval
Critical Thinker
blueoval's Avatar
Default Re: rotors
Another vote for QFM HPX pads and new rotors.
Depending on your driving style will be what rotor you choose to get.
i.e. Normal day to day driving in urban traffic and some highways, a standard rotor with better than stock pads is the go.
Spirited, urban, and hills driving I would recommend a slotted rotor with QFM HPX pads.
I went one up again, still went with a RDA/DBA slotted combination front and rear with QFM pads, but I also upgraded the front brake lines to braided for better brake feel and went to a higher quality brake fluid to avoid boiling.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 09-07-2012, 08:56 PM   #8
Uncle_Ken
Uncle_Ken's Avatar
Default Re: rotors
Lurker....
UK
Old 09-07-2012, 11:01 PM   #9
blueoval
Critical Thinker
blueoval's Avatar
Default Re: rotors
Lol. you love it UK.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
