Define definitive
Hey guys, the cruise control in my s3 xr6 manual doesn't work. It come up with 'cruise' under the odo meter but that's it. Thinking its maybe the brake light switch?
Cheers guys
BF F6 TYPHOON in NEO #718 ~ 356rwkw ![]() BF XR6 TURBO in SILHOUETTE |
Define definitive
Also all the brake lights are working
Could be the the cruise buttons on the steering wheel
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
meh.
![]() Join Date: Jul 2010
Check your horn Cassidy... Could simply be dodgy switches, or a broken clock spring.
RIP...
The clutch pedal may also be slightly down, resting on the switch.
. Oval Everywhere... |
5.6L x 2 pilot
![]() ![]() Join Date: Dec 2009
There is a failsafe switch attached to the brake booster master cylinder (the only wires on the MC). I have had to replace this in the past as it stops the cruise from engaging. Pretty cheap to replace too if I remember correctly.
Good luck with it. Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 ![]() 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
Define definitive
Ok cheers guys
Might sound stupid but is there anyway it check the cruise buttons on the wheel? Also the horn works fine..
#8 | |||
Only way to check if the buttons work is to take the airbag off. You will need the anti theft t-bits to remove the airbag. Then remove switches and check with a multi-meter. That is my assumption, I am not the best with electrical
#9 | |||
5.6L x 2 pilot
Just slidin'
Id seriously just check your brake lights first, all three of them.
MD Mondeo - For the family
#11 | |||
Walking with God
Exactly what you've described was caused by blown brake lights in my sedan. GK
#12 | |||
5.6L x 2 pilot
Just slidin'
Obviously paying more attention then what I am, lol. Sorry bout that.
#14 | ||
You can bypass the booster switch for testing by unplugging and inserting a wire link into the plug. (NOT THE BOOSTER SIDE).
BUILD AU II FAIRMONT GHIA HERS AU II Fairmont Ghia 7" DVD/GPS Radio 19" Wheels HIS FG XR8 Ute Lux Pack Tech Pack Touch Screen GPS |
#15 | |||
Got Ghia?
You've said the word cruise comes up, so the module is alive. The horn buttons earth through the CC, but they also use the same earth in the clock spring. The volume buttons also use that earth, so if they work, the return wiring is definitely fine. The cruise buttons do have their own feed through the clock spring though. I'd check the buttons/wiring for a voltage spike at the CC module across the Orange(Yellow trace) wire and earth, when someone presses either Set + or Set -. It will just be quick spike, and will be different for + and - buttons.
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold ![]() 2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers |
#16 | |||
Got Ghia?
You need to measure across the Orange-yellow wire and the black* wire. *There seems to be 2 black wires on the cruise module plug, one goes to earth from the module, the other into the module from the buttons. I haven't checked their location on the plug, but one should show 12v between the orange and it with the cruise on ("Cruise" on the dash), the other should show 0v. That's the one you want. Press a set button and see if you see the voltage move. Hope I got it right this time ![]()
