Old 07-08-2012, 06:17 PM   #1
tim_pato
tim_pato's Avatar
Default will a ba 5spd fit?
Will a ba 5spd bolt into a au?
tim_pato is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2012, 07:47 PM   #2
tim_pato
tim_pato's Avatar
Default Re: will a ba 5spd fit?
I assume there the same, please inform me if there is a difference.
Old 07-08-2012, 08:20 PM   #3
AU WGN
I'm keen to know about this too.
AU WGN is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2012, 08:41 PM   #4
tim_pato
tim_pato's Avatar
I have read so far this, mk1 ba's have the t5 as do all au's mk2 xr6t's have the t56 (6spd) do the later ba's have the t5 or the t56? Off to wikipedia->
Old 07-08-2012, 08:58 PM   #5
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
It'll fit...
... but, you probably won't have a speedo unless you get a T5 from an eGas.
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2012, 09:04 PM   #6
tim_pato
tim_pato's Avatar
Bummer, not questioning your aurthority, just curios as to what is different?
Old 07-08-2012, 09:09 PM   #7
tim_pato
tim_pato's Avatar
Really bummer as he will let it me pull for 400, cant make the speedo work? I take it the sensor/cog is different?
Old 07-08-2012, 09:24 PM   #8
XRGhia
meh.
XRGhia's Avatar
Rear extension housing doesn't have the speedo slot in it. If you have an AU extension housing already, just swap it over.
Old 07-08-2012, 09:28 PM   #9
tim_pato
tim_pato's Avatar
Is it a simple swap? Bolt off, bolt on? Does the ba internals still have the spirals on the drive shaft to turn the speedo cog?
Old 07-08-2012, 09:33 PM   #10
XRGhia
meh.
XRGhia's Avatar
I'd assume they do, but don't quote me...
Should just be a simple swap.
