Old 09-01-2013, 09:11 PM   #1
dogman
Default interior light
Hi guys,I have a 1999 Ford futura and the problem is my interior light wont go out automatically like it should.it just stays on and wont shut off.does anyone have any ideas how to fix this problem?
dogman is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2013, 10:21 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: interior light
I would start with the doors and see if the buttons are stuck
Uk
Old 09-01-2013, 10:33 PM   #3
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
is the switch turned on, the little lever on the side of the headlight switch?
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2013, 10:37 PM   #4
4ford
You might like to check the headlights switch.
Around the outer edge of the headlight/parklight rotary switch, there is another 'slider' type dimmer switch that controls both the instrument lights brightness AND (at full rotation) turns on the overhead light!
Check that it's not selected to overhead light on, which will keep that light on without fadeout!
Oops, just beat me to it!
4ford is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2013, 10:32 PM   #5
TheInterceptor
Cruising...
TheInterceptor's Avatar
Does it ever turn off? If its a door, it should go out after 15mins as the BEM will turn it off.
FBT '98
BA XT '04
F100 4x4 '82
Subaru Outback '02
TheInterceptor is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2013, 11:07 PM   #6
dogman
Tihanks guys problem solved.wife knocked interior light switch onto the one position when she turned headlights on....yes she has blonde hair..lol
