Old 05-04-2013, 08:15 PM   #1
wombat478
Default ute wont start start
I need help my 5.0 ute wont start just put in a starter motor was not that it just makes a clicking noise help me
wombat478 is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2013, 08:50 PM   #2
Gaz
Got Ghia?
Gaz's Avatar
Default Re: ute wont start start
Battery ok?
Got a multimeter?
Check the battery voltage while cranking then Check for volt drop down the solenoid sw wire as you crank. (probe the sw terminal and a B+ source)
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2013, 09:42 PM   #3
wombat478
thanks it wont even crank over but it will clutch start tried two batterys
Old 05-04-2013, 09:50 PM   #4
robbyj
Rob
robbyj's Avatar
the ticking usually means flat battery.. make sure you do the terminals up tight too, just sitting them on there without doing them up won't start.
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2013, 10:07 PM   #5
wombat478
yes all are tight I am lost I don't know what is wrong
Old 05-04-2013, 10:11 PM   #6
Gaz
Got Ghia?
Gaz's Avatar
Do you have a multimeter?
If not and you want to confirm it's not the starter (could still be the solenoid wire) look at the solenoid on the starter, there will be the thick B+ cable and another smaller wire attached to the plug on the solenoid. Disconnect this and jump a bit of wire from the b+ connection to this terminal on the solenoid and see if the started engages and cranks.
Make sure you hand brake is on and it's not in gear!!!
