Old 30-09-2013, 12:54 PM   #1
vbvbvb088
vbvbvb088
Default Difficult maintenance...
... for me was replacing all the water hoses on my JB Camira.
vbvbvb088 is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2013, 12:57 PM   #2
BHDOGS
Default Re: Difficult maintenance...
removing a rounded sump plug from a ba
Old 30-09-2013, 08:08 PM   #3
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
There is EASY maintenance????
I must be doing it wrong....
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2013, 08:26 PM   #4
XHBrad
XHBrad's Avatar
Air con filter on a Mazda 3
Current-2013 SR5 Hilux TJM bullbar and bashplates, 2" lift, spotties and awesome fuel economy
Previous-
93 ED XR6 5 speed, dumped and exhaust
97 EL Ghia auto luxury, on it's guts
94 ED Futura 5 speed tucking with exhaust
97 XH ute, 5 speed with P-Plate spec exhaust
98 AU1 forte AU gheyness
XHBrad is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2013, 08:46 PM   #5
GasoLane
Former BTIKD
GasoLane's Avatar
ANYTHING in a V12 jag engine bay
Old 30-09-2013, 09:41 PM   #6
Road_Warrior
Pity the fool
Road_Warrior's Avatar
Getting the oil filter off an early LS1 Commodore
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2013, 01:15 AM   #7
rog xc
Ford x series steering arms (all of them!)
rog xc is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2013, 11:32 AM   #8
mik
mik's Avatar
Difficult maintenance you say !.........Once upon a time i would do a 12 hour shift then come home and pull heads off a v8 and put it all back together without batting an eye lid, these days in my old age with dodgy bones and being a bit more porky just thinking about getting up from under the car is difficult maintenance, i end up getting there, but it takes a lot longer.
Old 01-10-2013, 08:45 PM   #9
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Changing the fuse in a LV Focus. The book instructions are useless and the guy at Ford wanted to charge me 70 bucks to do it for me, that was probably his trial and error pay as not even he could tell me where the fuses were located...
Harder still, the cabin filter, which requires removal of the whole fuse assembly...
___________________________
Old 01-10-2013, 08:46 PM   #10
Yellow_Festiva
Where to next??
Are they the same as what I described above?
Old 01-10-2013, 11:12 PM   #11
Bourbon Ute
Mazda 3 cabin filters are a two piece affair, requiring the fuse panel to be removed beforehand.
I remember removing a crank bolt off a VB-C(?) Commode V8 that had snapped off below the level of the balancer. Took an hour with a hammer and chisel lying on my back.
Although that's not really "maintenance".
Bourbon Ute is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2013, 12:28 AM   #12
nuthin' fancy
Lyminge, Shepway, Kent
nuthin' fancy's Avatar
The first wife
Mel Brooks sums it up best;
"Comedy is when you fall into an open sewer and die, tragedy is when I get a paper cut"
nuthin' fancy is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2013, 06:05 AM   #13
champ
champ's Avatar
Ha ha, very funny. Same would go for husbands I would say....
champ is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2013, 11:02 PM   #14
ebxr8240
Performance moderator
ebxr8240's Avatar
Relief ???
Daily driver GTE FG..
Old 03-10-2013, 03:03 PM   #15
Uncle Niceguy
my girlfriend and 2 sisters, very annoying haha
Uncle Niceguy is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2013, 03:15 PM   #16
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Cleaning intake plenum on NS Pajero... never, ever again.
Carless
Old 27-10-2013, 09:31 AM   #17
Olbucko
Olbucko's Avatar
Getting the pitman arm off was easy, but only if you had the special puller supplied by Ford. Normal pullers would not grip the arm properly.
How about changing the power steering box in a EFI unleaded XF or ZL Fairlane, in the XD and XE the job was a bit awkward, so Ford fitted a bigger brake booster and a cat to the XF/ZL to make it a real challenge
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
Olbucko is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2013, 11:14 AM   #18
vbvbvb088
vbvbvb088
I remember spark plugs on VK V8 Calais... near brake booster.
Old 27-10-2013, 08:52 PM   #19
AJ09
Not that "difficult" but still a real pain:
Timing belt on a 1989 Camry.
Lots of skin taken off the knuckles and a fair amount of swearing too....
AJ09 is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2013, 09:12 AM   #20
TheSneakiness
Adapt or perish...
Headlight globes on AU/BA Falcons...
If you have big hands like me its not easy.
Carless
Old 28-10-2013, 11:07 AM   #21
mechanic
Bypass hose between the head and block of the early BMC minis and 1100's.
Anyone who's ever done them will know what I'm talking about.
mechanic is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2013, 01:37 PM   #22
Bulandgoose
Bulandgoose's Avatar
Replacing the accessories fuse in my niece's 2011 Suzuki Swift.
Actually I never found it; I laboriously pulled out and checked every fuse I could find in the two fuse compartments.
None of them were blown. In the end she had to wait until it went in for a service, and Suzuki fixed it then.
But nobody would tell me where the fuse is actually located; they just waffled on about it being "in the handbook".
It's a really crap design; it has a vertically mounted "cigarette lighter" type socket (except you can't use a lighter in it as it's only meant for low-power gadgets), and if a coin falls in there, ♪♫*splat* goes the fuse-ee♫♪.
If I could have found the fuse I would have done what I've with similar setups in other cars: Solder a Polyswitch (self-resetting electronic fuse) across the old fuse and plug it back in. Never fails after that.
I don't suppose anybody here knows where the fuse lives....
Bulandgoose is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2013, 01:43 PM   #23
Olbucko
Olbucko's Avatar
I remember them, it was almost easier to lift the head to get the hose in.
Old 31-10-2013, 07:01 PM   #24
ebxr8240
ebxr8240's Avatar
there is a compressible hose availabe
Old 31-10-2013, 09:35 PM   #25
Bulandgoose
Actually in the 1960s I had this rev-head neighbour who'd fitted some sort of V8 engine to an old Mk I Ford Zephyr. (In case you don't know, that was a 1950s Pommy car that Ford USA copied to make the Falcon. Yes, they actually sold left hand drive Mark I Zephyrs in th' USA!)
I didn't know much about cars then, but I remember my brother saying that to change the spark plugs he had to remove the front mud guards!
Given the Mk I's propensity for breaking axles even with its original smallish 6, I presume he must have also improved the back end somewhat :-)
Old 31-10-2013, 10:22 PM   #26
b2tf
not here much anymore
b2tf's Avatar
Worst one I have found so far is globes on a Ssanyong Acyton ute. Front bumper has to come off.
2024 F150 XLT
Old 31-10-2013, 11:03 PM   #27
XR Martin
XR Martin's Avatar
To replace the turbos on a late model diesel LandRover, you have to take the body off the chassis.
2004 BA wagon RTV project.
