Old 24-05-2015, 10:13 AM   #1
Tickford08
Exclamation Help au instrument cluster
Hi all I need some help quick.
I have AU 1 / I Fairmont Ghia Tickford series. With this cluster / instrument
Attachment 87809
https://lh6.googleusercontent.com/pr...g=w597-h246-nc
And replacing with this one
AU 2 / II Tickford dash from
My problems are this:
My oil pressure dial not working
My fuel and speed averages and dte don't work on the climate control
My interior lights do not work when door is open but ajar symbol dose
Everything els was a good swap fully functioning with drams
I need help on these issues
Tickford08 is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2015, 10:21 AM   #2
Tickford08
Default Re: Help au instrument cluster
And unsure if low Coolant has a function on the dash
Old 24-05-2015, 02:37 PM   #3
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Cool Re: Help au instrument cluster
I did this
http://www.fordforums.com.au/showthr...1238536&page=5
but I had a series II standard cluster. The above is what I did to make it work for an AUII Forte.
Look on page 2 of the tech guides as well
UK
Old 24-05-2015, 03:11 PM   #4
superroo
You can't stop the signal
superroo's Avatar
1: XR is a faux oil gauge. It works on a pressure switch same as low series dashes. You need to swap the sensor on the engine.
2: XR dash doesn't have the data output like the Fairmont. Don't believe there is a solution. If there is, it's something internal to the clusters.
3: Fairmont has input for each door, XR only has 1 input for all. You need to bridge all four door wires into 1 (driver's from memory)
