Old 11-06-2015, 06:06 AM   #1
NCII40
XR6T BA 2002
NCII40's Avatar
Default IRS diff swap out
My R31 3.89 diff with 4 pinion VL turbo LSD is on its way
Had it built by Glenn in Dandenong ( vicmelboz differential )
Can someone please give me a guide on how to do the diff swap
I have never done an IRS diff before
XR6T 2002 BA
NCII40 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2015, 06:13 PM   #2
NCII40
XR6T BA 2002
NCII40's Avatar
Default Re: IRS diff swap out
anyone help
XR6T 2002 BA
Old 11-06-2015, 06:39 PM   #3
mcfly94
mcfly94's Avatar
So youve had this built all into an au housing?
if not youll have to pay someone to do that.
But if all in au housing ready to go its pretty easy, remove spring assemblies, undo top control bolts to stub, undo tailshaft, remove half shafts, undo 3 bolts and its out, reverse the procedure.
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2015, 06:33 AM   #4
NCII40
XR6T BA 2002
NCII40's Avatar
Yes built into AU housing , all ready to install once it arrives
Thanks for the guide mate,
Is there any other heads up like may need to replace anything through out the swap out?
Any special tools that i may not have? etc
cheers
XR6T 2002 BA
Old 13-06-2015, 05:25 PM   #5
NCII40
XR6T BA 2002
NCII40's Avatar
Need Help Please
Exhaust is out
tailshaft will be out shortly
how do i remove half shafts,
where is the bolt for the remove spring assemblies,and top control bolts to stub,
cheers
XR6T 2002 BA
Old 13-06-2015, 05:36 PM   #6
mcfly94
mcfly94's Avatar
crow bar gently or big tyre lever will pop the half shafts out
bolt is right at the bottom of the shock and inside the towers of the car, top lca bolt to stub is pretty clear to see, wont miss it.
Old 13-06-2015, 07:35 PM   #7
NCII40
XR6T BA 2002
NCII40's Avatar
Thanks for your help
Tail Shaft out
abs sensors off
shocks out
2 bolts rear of diff out
1 bolt under diff loose
do i jam my massive screwdriver here as pictured to pop these half shafts
XR6T 2002 BA
Old 13-06-2015, 08:01 PM   #8
NCII40
XR6T BA 2002
NCII40's Avatar
can anyone help
XR6T 2002 BA
Old 13-06-2015, 09:05 PM   #9
NCII40
XR6T BA 2002
NCII40's Avatar
bump.............................................. ....
do i need to remove brakes and hubs or not
XR6T 2002 BA
Old 14-06-2015, 12:46 AM   #10
BOTTLEDUP
BOTTLEDUP's Avatar
Sounds like you need a workshop manual...
T1 TE50 P01
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2015, 10:45 AM   #11
NCII40
XR6T BA 2002
NCII40's Avatar
i do but thanks
XR6T 2002 BA
Old 14-06-2015, 10:55 AM   #12
T MAN
T MAN's Avatar
yes, undo and move the brake caliper to one side, undo the top and bottom bolts holding the hub upright and carefully leaver the drive shaft between axle and centre housing and with a little force it will pop loose.. pull the shafts out enough to clear the centre..
T MAN is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2015, 12:52 PM   #13
NCII40
XR6T BA 2002
NCII40's Avatar
Thanks T-Man
One side popped out, had to remove toe link on drivers but passenger wont budge and the bolt holding toe link in on sub frame fails on fuel tank so i cant get it out
gonna need new upper and lower control arm bushes now and toe links
XR6T 2002 BA
Old 14-06-2015, 12:56 PM   #14
T MAN
T MAN's Avatar
You can undo the toe links from the hub end..
Old 14-06-2015, 01:01 PM   #15
NCII40
XR6T BA 2002
NCII40's Avatar
I cant get it budge
XR6T 2002 BA
Old 14-06-2015, 10:22 PM   #16
NCII40
XR6T BA 2002
NCII40's Avatar
Got it, bashed it with hammer
3.9 diff in all back up except exhaust
my procedure i did
Crack wheel nuts
Jack car + stands
Take wheels off
Undo cat back and remove
Remove tail shaft but mark all points and locking nuts
remove brake calipers and set aside on milk crate
take off rear discs
Remove Rear shocks and spring complete unit
remove rear toe link on hub, its just one nut but your gonna have to keep nut on the end and bash it with a hammer up so it will pop out cause my were a pain and i don't know why and now i need new ones but anyway
remove upper control arm bolt need breaker bar, beware of falling perished bush particles
remove lower control arm need breaker bar , beware of falling perished bush particles
get another milk crate ready and pull toward you the half shaft and then reach in and pull it out of diff, crow bar and screw driver did damage and wouldn't pop it
Remove abs sensors
Drain diff oil
2 bolts rear of diff remove
get jack under diff with wood ready to drop
1 bolt under diff undo
drag diff out on trolley jack
XR6T 2002 BA
