I've looked and searched dose anyone have a tutorial on how to remove the dash from a S3 forte?
Chairman & Administrator
![]() ![]() Join Date: Dec 2004
There are tutorials in the tech portal to remove the Instrument Cluster, Centre Stack & Audio System and the Entire Dash Assembly.
Cheers Russ
Observatio Facta Rotae
#3 | |||
You can't stop the signal
Tips:
- PAB doesn't need to be removed from dash - Column can be dropped down to something resting on the floor, rather than be removed. - I've found it best to remove: Console, front seats, front door trims, steering wheel. The dash is large and awkward to move. Easier to remove those than protect and worry about them. - It can be done with one person. Not easy, but possible.
thank you and thank you. i looked for 5 hours trying to find something this detailed
