Old 04-02-2019, 10:15 AM   #1
mike_nofx
mike_nofx's Avatar
Default Heat resistant paint or coating?
I have a bit of a query regarding what options to use to change the colour of a wood heater.
I have a Norseman wood heater in brown that is basically this exact one:
So its a thicker steel box, surrounded by a sheetmetal cover which is some kind of enamel or powdercoat. With a newly renovated room, brown no longer suits and it would be good to change it to black.
I think powdercoating would be the best option if it can stand up to the heat. Being that the sheetmetal is more of a cover with a bit of an airgap and not in direct contact with the fire itself, it just MAY be ok. I never actually tested surface temperatures though.
Also the Flue is brown which may be more of an issue.
The other option is a potbelly paint, but it seems like a messier option which wouldnt have as good a finish, and probably easier to scratch.
What can you recommend?
mike_nofx is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2019, 10:43 AM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
Default Re: Heat resistant paint or coating?
https://www.stovebright.com.au/paint-powder
Old 04-02-2019, 11:27 AM   #3
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
from a car forum - how about exhaust header paint?
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2019, 11:31 AM   #4
mike_nofx
mike_nofx's Avatar
Thanks for the suggestion.
I forgot to mention, one concern I have with heatproof paints such as what you suggested is that to cure the paint it must react a certain temperature. For that product you mention it’s 600f or 350c. I’m partly concerned that the surfaces I wish to paint may never reach that temperature and so I assume will never fully cure.
I only wish now that before removing the wood heater that I tested all surface temperatures with a heat gun with the heater at full temperature. Then I could have determined if powdercoat is adaquate or if I needed heat paint.
Old 04-02-2019, 02:30 PM   #5
roKWiz
Cabover nut
roKWiz's Avatar
mike_nofx This is my solution for a coating.
heritagestonemason.com/Fordlouisvillerestoration
In order that the labour of centuries past may not be in vain during the centuries to come...... D. Diderot 1752
roKWiz is online now   Reply With Quote Multi-Quote with this Post
