Old 27-07-2005, 09:11 PM   #1
b2tf
not here much anymore
b2tf's Avatar
Default Wiring Loom
I seem to remember when I was messing round with Microcat that there is a loom you can buy for AU sedans. It is the loom which powers the rear footwell courtesy light (built into your centre console under the air vents) and goes for about $18. I know its a long shot, but does anybody know the part number, and better still, does anybody know how it connects with the power source at the other end (in the centre console somewhere)?
2024 F150 XLT
Old 18-11-2005, 02:44 PM   #2
Engineer
Cookie Monster
Engineer's Avatar
Default Rear Footwell Light
Hi Guys,
I have been wanting to do this for ages but i did not want to rip the console off to not find any loom to plug the light into. Is there a std loom connection there for the light? My car is a AU series 2 XR8.
Any help would be appreciated!!
Engineer
Engineer is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2005, 06:25 PM   #3
b2tf
b2tf's Avatar
Engineer,
there isnt a loom in there from factory unless yer car is a Ghia or Fairlane etc. Fairmonts dont have it so XR's definately wont.
But as I said in my first post I am sure there is a loom you can get to fit in there. Even if there isnt, its not by any means hard to knock one up yourself.
2024 F150 XLT
Old 19-11-2005, 09:12 PM   #4
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
AU2 13B711 A 18.00
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2005, 03:59 PM   #5
Engineer
Cookie Monster
Engineer's Avatar
U R a legend Russ!!!
cheers
Engineer
Old 25-11-2005, 01:58 PM   #6
Engineer
Cookie Monster
Engineer's Avatar
Default lamp lens part no.
Hi Guys,
If you want to do the rear footwell lamp modification on your AU falcon. You will need the following
1) Wiring Asy-courtesy lamp AU2 13B711 A
2) lamp lens EF13K707A
3) 1 globe (sorry no part number!!)
Engineer
p.s maybe we can add these parts into the au parts database too!!
Old 25-11-2005, 11:45 PM   #7
12
Silhouette AU1 TS50.
12's Avatar
The numbers are already there. :voldar02:
AU2 13B711 A WIRING COURTESY LAMP, LESS MOBILE OFFICE, 4 DR SED, FORTE/S $14.80
EF 13K707 A LENS, FAIRLANE/GHIA/LTD $6.76
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947)
PIC'S OF MY
T1 TS50.
12 is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2005, 02:56 PM   #8
Engineer
Cookie Monster
Engineer's Avatar
Default Rear Footwell Light Update
Hi All,
Just a small update for those contemplating this modification ( I strongly recommend it it looks great!).
The wiring loom AU2 13B711 A will NOT fit straight in to the std XR8 AUII console, . The AU2 XR8 console has hole for a bayonet style plastic housing (like the side blicker globes or the rear brake light globe). The wiring loom is wired for a long globe with metal ends (like the old glass fuse style). as a result it does not marry up. So I got a plastic bayonet fitting from the the tbar shifter gloge of an old au and soldered the wires on. I also wired it into the green/yellow stripe wire and the black/blue stripe wire in the loom that goes over the transmission hump under the console.
It worked a treat and looks fantastic. Worth the effort for sure..
Engineer
Old 11-03-2007, 04:39 PM   #9
Luke Plaizier
Lukeyson
Luke Plaizier's Avatar
Topic Dredging...
Hey Russell, do you know if the same lamp assembly fits into the hole at the back of the BA Console?
If not, is there any chance you know the part numbers for the BA unit? I'll be wiring it up myself.
Lukeyson
Luke Plaizier is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2007, 09:00 PM   #10
russellw
russellw's Avatar
As far as I know they are a carry over item.
Russ
Old 13-03-2007, 12:18 AM   #11
Mechan1k
Mechan1k's Avatar
I was looking at running vents through my centre console (in a ute though) .... to cool my sub amp that sits directly behind it.
But I'd say there's going to be a hell of a lot of ducts i need to run through to do .... so I have put the idea on hold ... for a long time.
Old 13-03-2007, 08:58 AM   #12
HLC
Audi S3
Originally Posted by b2tf
Engineer,
Fairmonts do have it. i put a blue LED in my rear courtesy/footwell light.
Old 13-03-2007, 08:59 AM   #13
HLC
Audi S3
just put a couple of PC fans there. no ducting needed.
Old 13-03-2007, 11:29 AM   #14
b2tf
b2tf's Avatar
weird, my parents AUII doesnt have the loom there.
2024 F150 XLT
Old 13-03-2007, 12:27 PM   #15
Luke Plaizier
Lukeyson
Lense ordered. I'm not sure what I'm getting - service guy couldn't help much, he didn't have a picture. $11 new. What I hope I'm getting is the clear lense and the backing plate for a globe holder - it has been mentioned here that the Globe Holder itself is part of the harness.
However, not certain right now.
I found a site that someone has done a writeup on installing it into a BA: http://au.geocities.com/neon_lightbu...amps/index.htm
And to honest, while the 'Mod' instructions were absolutely fantastic on car disassembly, they were a bit short on the components and the wiring.
Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it.
Old 13-03-2007, 07:32 PM   #16
Mechan1k
Mechan1k's Avatar
Not a bad idea actually.
Did the sedans come with vents in that section???
I am presuming they did.
If I can get the section that has the vents i might try it.
Old 13-03-2007, 07:57 PM   #17
HLC
Audi S3
sure did.
and knowing ford, the airducting is probably there at the bottom of the console, so you just need a sedan console to "plug" in :
Old 13-03-2007, 07:58 PM   #18
HLC
Audi S3
the last 4 or 5 fords we've had have had the light there.. strange. although my dads BA doesnt. no loom either.
Old 13-03-2007, 08:18 PM   #19
Mechan1k
Mechan1k's Avatar
sure did.
I had my console out yesterday afternoon replacing the Autoshifter globe ... no ducting .... wonder if it moulded into a sedan console though ... might see if they are pretty much the same.
Eventually I will have the centre console replaced as I have drill holes in mine from the work 2-way data terminal (they are going to new handheld units soon so doing away with the old cumbersome unit) ... so it might be time to look for a sedan centre console.
I think under the dash the foot vent is split in 2 already on the ute ... so it looks like it is really to have a duct fitted over one side to divert to the rear.
Old 13-03-2007, 08:33 PM   #20
HLC
Audi S3
woops i meant at the bottom of that dome centre thing where the radio and that is. when you pull out a sedan console, there is airducting there, which connects to the ducting in the console itself which goes to the rear vents! its really hard to explain!!!!
Old 13-03-2007, 08:43 PM   #21
Mechan1k
Mechan1k's Avatar
I think I know what you mean ... I have no ducts there ... I just have the AUTO ECU/PCM mounted under there ... nothing else to connect to.
Old 13-03-2007, 11:26 PM   #22
b2tf
b2tf's Avatar
Only difference between the sedan and ute consoles is the bit at the back, on the utes it has a plastic cover with no vents whereas on sedans it has the vents and the bezel for the rear courtesy light.
The A/C ducting itself isnt moulded into the console, its a seperate part. As Simon said, on the utes the ducting doesnt come down to meet it under the radio fascia, so it would be a bit of work to put it in.
2024 F150 XLT
Old 13-03-2007, 11:27 PM   #23
Mechan1k
Mechan1k's Avatar
Might be able to just replace the cover with vents then ... and then use PC fans behind that
Old 13-03-2007, 11:34 PM   #24
b2tf
b2tf's Avatar
yeah no reason you couldnt, im considering changing mine for the sedan one so i have the rear light, i hate it when you drop stuff behind the seats and cant find it in the dark. that and i just want another excuse to mess with the car.
2024 F150 XLT
Old 13-03-2007, 11:39 PM   #25
Mechan1k
Mechan1k's Avatar
If i can get the light as well I might play with something (or I'll get Stav to as I am crap with electrical stuff).
Not much room for me to lose stuff behind the seats ... but I have a bunch of crap sitting ontop of my amp though.
Old 14-03-2007, 10:44 PM   #26
TICK4D-TAS
Club Moderator
i did this to my xr8 when i first bought it. i bought the loom from ford with the lense and globe. it pluged into a socket under the passenger side front seat. i used my mates te50 as a guide when we did it.
TICK4D-TAS is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2009, 01:36 PM   #27
_CRUZ_
Ford Owner
_CRUZ_'s Avatar
wow old thread, i want to try this and im hoping theres a plug under the consol to plug up a new loom, i have an au1, if not maybe ill have to solder i guess.
_CRUZ_ is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2009, 01:45 PM   #28
InfernoSR
Sales Representative
InfernoSR's Avatar
Just a side note... my AU1 Forte didnt have one (does now... made my own) but my AU2 SR has one from factory...
