Old 08-08-2005, 07:36 PM   #1
PULLY6
PULLY6's Avatar
Default "Check ABS" light
G'day all
Last week my "Check ABS" light would come on every now and then. Last night the bastard turned on halfway home, and stayed on.
Brett (lunaefghia) drove my car the other night and remarked how firm the brake pedal is - i've been noticing it getting harder and harder to brake lately.
The fluid is top notch, the pads are fine..... what could be the problem?
Pully
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust
PULLY6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2005, 07:36 PM   #2
FordFan86
meow
FordFan86's Avatar
To much ing single spinning and going sideways with said single spinning and thrashing your brakes perhaps?
Originally Posted by Pully
Oh, i've got brake fade, that was quick... oh well..
FordFan86 is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2005, 07:47 PM   #3
Stav
Smile
Stav's Avatar
I was finding the check abs light kept coming on freeway trips. Or trips at around 100 kmph.Our front wheels have electronic sensors attached to them.From memory dust gets in and sets the light off.From memory all i did is get the hose and clean the area out.
Old 08-08-2005, 07:50 PM   #4
BuuBox
I had a mechanic mate who changed the rotors on a EF, and it seemed the sensor was damaged, and it constantly thought the brakes were locking... wrote off the car through someones front fence, and nearly killed himself.
So yeah, if it's getting harder and harder to brake, watch yourself!
BuuBox is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2005, 08:02 PM   #5
NZ
NZ's Avatar
Usually a damaged brake booster will caue firmer braking. Can you hear a sucking when you apply the brakes?
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
Old 08-08-2005, 08:10 PM   #6
PULLY6
PULLY6's Avatar
At this stage I can't - though I'll check the slides and booster on thursday.
Old 08-08-2005, 08:17 PM   #7
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
They're fairly common to crack too as they're plastic.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2005, 09:49 PM   #8
Xplodefalcon
Custom User Title
Xplodefalcon's Avatar
Mine done the same thing, took it to ford and they said the comp had sh!t itself, and would be worth the $$$ to fix, so they disconnected it for me, brakes atleast work now.
When my Check abs light was on, the pedal would drop while trying to brake without lock up, that was scary!!
Xplodefalcon is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2005, 12:41 PM   #9
KEV EB XR8
XR8 v Lee. love you Lee
KEV EB XR8's Avatar
Default had the same problem , this might help
Originally Posted by PULLY6
G'day all
Pully
mine came on the first time only at high speed , stopped turn off , restart , ok . sought advice and (in my case) system self diagnose at start light off ok sensor disabled (1) high speed but computer reset at start . pickup sensor was loose and dirty causing the problem . never happened since , that was 4 months ago. hope it helps . cheers.
KEV EB XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2005, 03:27 PM   #10
PULLY6
PULLY6's Avatar
Thanks mate, but I'm struggling to understand what you just said. Can you try again? Or is it just me?
Old 09-08-2005, 03:43 PM   #11
montyv8
Turbo Dinosaur FTMFW
montyv8's Avatar
hmmm i think kev's reply could have been structured a bit better.
i think he's saying the abs sensor on the stub axle was loose and dirty, with a clean up and tightening the mounts it worked ok.
1973 XB Fairmont Coupe, turbo EFI SBF
8.23@168MPH
montyv8 is offline   Reply With Quote Multi-Quote with this Post
Old 09-08-2005, 03:51 PM   #12
FordFan86
meow
FordFan86's Avatar
Well i hear a sucking noise when i apply the brakes, only really sitting still at lights taking them on and off, and i think i may have a slight leak in my master cylinder... oh well..
Old 21-11-2005, 02:53 PM   #13
rdomain
Sonic DV8
rdomain's Avatar
Hey Pully,
Did you end up sussing this out as I just bought an EB XR6 and the light has come on after the battery was disconnected and it won't go away. Brakes feel fine.
r.domain muzak
Velocity BA XR6 MkII Turbo Ute
White EB XR6 S MkII Sedan
rdomain is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2005, 04:41 PM   #14
bdennis
RDOmain,
Mate. You prob need to put the ABS system into diag mode and get the error code from it. See here
http://www.fordmods.com/forums/documents.php?doc=48
bdennis is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2005, 08:04 PM   #15
PULLY6
PULLY6's Avatar
Hey Ritchie, nah I haven't got it sorted as yet. I changed the rotors and pads, now I'm thinking the booster is damaged... $$$
Is your pedal firmer?
ps How come you bought an EB XR6? What happened to the ute?
Old 22-11-2005, 09:29 PM   #16
rdomain
Sonic DV8
rdomain's Avatar
Cheers for the link bdennis. Very helpful. I'll have a shot at that this week and see what goes.
And Pully; the pedal doesn't appear to be firmer. The light came on after the battery was disconnected a few times but now it wont go away. And don't you worry, we still have the ute Won't be getting rid of that baby!
http://www.fordforums.com.au/showthr...d=1#post418175
(gf wrote off the other car we had and don't worry, she wasn't hurt and it was only a VT) so we thought we'd replace it with the original XR6
r.domain muzak
