How common throughout the E series is Thrustrace rattle.
Anyone have the same experience. Last edited by Wicherts; 08-08-2005 at 10:05 PM. |
Thrustrace ?
When I changed my clutch I noticed that all the bolts on the extension housing were very loose, it caused a major rattle. |
slow & low EA Ghia
thrustrace????? im thinking you mean thrust bearing? never heard that term for it though, but im not that knowledged, as far as ive heard e-series gearboxs have more problems with synchros then with thrust bearings. thrust bearings are only about 5bux but its a to take off the gearbox to change with out a hoist. so if your getting that changed then there going to charge at least a hundred bux just to take off the gearbox and put the new one in and refit the gearbox.
Ehab
Ea Fairmont Ghia 1988 |
![]() Join Date: Dec 2004
And here I was thinking that was a catalyst for contracting an STD!
#5 | |||
Yes thanks for that guy's . It's something I will have to investigate further.
GT4.
It happened to me Wicherts. A brand new thrust bearing will cost you anywhere from 40 to 90 bucks depending on where you get it from.
My uncle and I changed the one on my old manual EF cuz it was whining like buggery (and as dry as a nuns.. well, you get me. ![]() ![]() Not a hard job but thats what your problem is, so there ya go ;) |
Thanks Danny i appreciate it.
Lovin the Manual.
$78.80 from ford and bursons costs more like $85.00 or something
i put a new one in on the weekend, as my old 5-speed had a bad thrust bearing noise i thought it was safe to change this one before i put the new box in. |
1990 EA Falcon S Driver
Hi guys,
Is this anything like the rattling noise I get in 3rd gear when the car is under a load when its cold? It seems to dissapear when its hot but the noise sounds like its coming from the gearstick and and is similar to the sound of a nut been shaken in a glass jar quickly. Any ideas? Mark. Last edited by MintEAFalcon; 12-08-2005 at 02:08 PM. |
02/90 EA II Fairmont
maybe theres a nut and a glass jar inside your gearbox?
211RWKW EA |
#12 | ||
Maybe he was after a valid reason to his problem?
possibly... whatever it is, the oil thinning out when it warms up seems to be fixing it, right?
211RWKW EA |
#14 | ||
Former E-Series Member
If that's the case, a fluid change would be a good start.
#15 | ||
castrol trans max z is a lot thinner too..
211RWKW EA |
