Old 19-08-2005, 03:31 PM   #1
DOMN8N
AKA ___DOMMUZ
DOMN8N's Avatar
Default can A EL roof lining fit a ea
i need a new roof lining on my ea because it sunk and i need to now if an el 1 will fit because i now where i can get 1 really cheap
DOMN8N is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2005, 03:35 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
buy it and try it, i want to know the answer too.
Old 19-08-2005, 03:36 PM   #3
EFFalcon
Last warning
EFFalcon's Avatar
i can't think of any reasons why it wouldn't.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 19-08-2005, 03:37 PM   #4
CruizinEB
me to, aneone
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2005, 03:41 PM   #5
DOMN8N
AKA ___DOMMUZ
DOMN8N's Avatar
because i think they heve the same cabbin shape yeah
Old 19-08-2005, 03:43 PM   #6
EA2BA
PM me if you want
EA2BA's Avatar
if your ea one is stuffed, pull it out, lay it on top of the EL there will be the answer in all of 2 seconds.
Old 19-08-2005, 03:47 PM   #7
DOMN8N
AKA ___DOMMUZ
DOMN8N's Avatar
yeah might try that
Old 19-08-2005, 03:51 PM   #8
CruizinEB
Me to
Old 19-08-2005, 03:52 PM   #9
CruizinEB
Me to
Old 19-08-2005, 04:38 PM   #10
InitialD
Low and Loud
InitialD's Avatar
Originally Posted by CRUIZIN EB
Me to
No need to post again mate :yeees:
the EL roof lining will fit EF/ED/EB/EA cause they are all identical!
My lining came out of a EL fairmont.
Old 19-08-2005, 04:41 PM   #11
DOMN8N
AKA ___DOMMUZ
DOMN8N's Avatar
thankz
Old 19-08-2005, 04:57 PM   #12
mcflux
mcflux's Avatar
The perfect answer ;)
Is your lining only sagging? If so, no need to replace, simply take off the plastics which pinch around the edges of the lining, pull the lining all the way off to the sunvisors, and use some "Glue-in-a-can" stuff (sorry, don't know the name of the stuff).
It's like a spray-on glue in an aerosol can. Spray a small amount evenly on the roof, then rub the roof lining back onto it. It should stick to the roof now ;) Take care in not getting any creases/crinkles in the roof, so rub it in thoroughly.
Also, use either breathing apparatus or do it with all the windows down! That stuff is nasssssty!
-Dave-
*EDIT* w00t! 1000th post! (does the happy dance)
Old 19-08-2005, 05:01 PM   #13
InitialD
Low and Loud
InitialD's Avatar
Contact Adhesive is what your thinking Dave ;) and you are right on the money with that reply :P
Old 19-08-2005, 05:06 PM   #14
mcflux
mcflux's Avatar
Contact Adhesive eh...
Oh, yeah, don't spray it on the whole roof at once! Do like 20cm stages at a time working from the front to the rear of the car ;)
Doing the whole roof at once would result in:
* 90% of the adhesive drying before lining is applied
* Death by chroming
-Dave-
Old 19-08-2005, 05:08 PM   #15
InitialD
Low and Loud
InitialD's Avatar
Originally Posted by Ghia5L
* Death by chroming
wouldnt want that :P be all shiney and what not j/k
Old 19-08-2005, 07:00 PM   #16
Walkinshaw
Two > One
Walkinshaw's Avatar
Gaurentee you it will fit as does the dash, seats, trims ....etc etc
Old 19-08-2005, 07:13 PM   #17
LUXO_8
windsor user
haha yeah good point:P
Old 19-08-2005, 08:57 PM   #18
Rmyers
Does Steve have a car?
Rmyers's Avatar
NOTHING from EA and EF/EL are interchangeable, so your just gunna haveto stick with EA parts :P
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2005, 05:43 AM   #19
Walkinshaw
Two > One
Walkinshaw's Avatar
LOL, I've ditched my hybrid so I'll contradict that point. EVERYTHING swaps over
Old 20-08-2005, 07:55 AM   #20
Papa Smurf
Papa Smurf's Avatar
I have an EB Falcon series one and the hoodlining in the little beast has begun to balloon as well. In my spare room is a BRAND NEW EF sedan hoodlining and it WILL fit in the white knight.
There are a LOAD of goodies that DO fit from EF, EL, and, AU.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2005, 05:44 PM   #21
DOMN8N
AKA ___DOMMUZ
DOMN8N's Avatar
and el or au mirros as well i got one now
Old 21-08-2005, 09:07 PM   #22
cogo81
cogo81's Avatar
* Death by chroming
-Dave-
sorry I'm going to have to contradict you here, the best way to do it is to pull the hoodlining out to work on it, peel the hoodlining back half way then spray the contact to both surfaces and allow to tack off for a couple of minutes and then slowly reapply the lining to the backing working all the wrinkles out as you go, and if need be repeat to the other half of the lining.
cogo81 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2005, 11:45 PM   #23
cominthru
Doof Doof Operator!
cominthru's Avatar
dam i had some problem! this is something i just finished doin!
not EL lining...just the original roof relined in black vinyl...something different, worked out better than i expected. Heres a pic:
EB2 Turbo & Territory SZ Titanium
cominthru is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 09:21 AM   #24
mcflux
mcflux's Avatar
Looks mad :evilsasmo
As for the contradiction, it's all good! Since you say your method works, it'd be much easier than doing little bits at a time like what me & my mates did with his EA. :voldar02:
-Dave-
Old 22-08-2005, 05:57 PM   #25
Papa Smurf
Papa Smurf's Avatar
Cominthru, love the Black Hoodlining. Is it very hot inside?
Old 23-08-2005, 12:28 AM   #26
cominthru
Doof Doof Operator!
cominthru's Avatar
dunno it's still winter!...but even with the other parts done in black it doesnt get much hotter at all i dont recon.
Old 23-08-2005, 12:35 AM   #27
InitialD
Low and Loud
InitialD's Avatar
it wouldnt get much hotter then normal. But A/C allways helps ;)
thats like something from "pimp my ride" I likie likie :Reverend:
Old 23-08-2005, 10:24 AM   #28
TadKa
Wait? What?
TadKa's Avatar
good grief. that looks bloody awesome. love the paintwork and wheel.
TadKa is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2005, 02:05 PM   #29
Rmyers
Rmyers's Avatar
Black absorbs light, but it's not an insulator as your suggesting. A black rooflining will not make the car any hotter...
AKA Mr Silver
Old 23-08-2005, 08:47 PM   #30
cominthru
Doof Doof Operator!
cominthru's Avatar
yeh thanks tadka!
i just need some of the Black EA interior door handles n should be awesome!
oopz slightly off topic!
