Old 13-09-2005, 08:54 PM   #1
brax
EL-Brax
Default keep EA or get ED or EF
Ok here is my dilemma:
I have currently an EA
problems with it include:
1) a bit of rust above the front/main windscreen
2) a bit of rust in the rear right wheel arch
3) auto transmission having issues(i.e. at times i would lose all 'gears' in that the car was rolling after turning a corner ,however in 'D' there was no engagement of a gear for about 10-20 secs)
4) more than likely head gasket is going
5) losing water somewhere
6) oil leaks (from rocker cover gasket and possibly head gasket, you can see the oild at the front of the car)
7) The heater sometimes works
8) I have had the cabin of the car fill with smoke twice(possibly has something to do with (7)
9) something goes clunk when turning(does not sound like a good clunk)
All these problems can be fixed, this i have no doubt, however would it be better, to get another car, i.e. An ED or EF??
keep in mind that this is a series 1 EA, no rear stop light on the rear parcel self, an aftermarket one has been installed. Also another thing to consider is that it is dual fuel...
Any help would be mostly appreciated.
brax is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2005, 08:59 PM   #2
XRated
Shoot.
XRated's Avatar
Hmm sounds troublesome. If I was in your position, I'd be looking for a clean EF on gas. Otherwise if you come across a VERY good example of an ED with low kms on gas (maybe a Ghia? XR6 etc) maybe that'd be worth a look. Bloody cheap these days = great value for money.
20V Turbo
Old 13-09-2005, 09:11 PM   #3
INJECTED_250
Custom user title
INJECTED_250's Avatar
Man.... id go for and Eb2-ED fairmont ghia...... CHEAP AS and worlds away from an EA
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2005, 09:34 PM   #4
CruizinEB
i would say go for the EB2 mine only cost me $2000
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2005, 09:34 PM   #5
Damo
fix your EA and save up for another car which is not an E-Series, like a BA XR6T :P If I had my time over this is what I would have done.
Old 13-09-2005, 10:06 PM   #6
Age182
GMHKLA number plates
Age182's Avatar
go an EF mate there all good ;)
Currently owned: 1997 Hyundai Excel (the daily)
2009 FG FPV F6 Silhouette Auto
Previously owned:
1994 EF fairmont Ghia 4.0Ltr, AUTO
14.620@93.3mph
2000 Honda S2000
14.73@92mph (stock + no traction)
Age182 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2005, 11:43 PM   #7
EA_Hooligan
Blown Head
Look mate, you are planning on basically getting another E-series which means you are going to get exactly the same problems you currently got in a few years time. You should either fix the problems you currently have, upgrade to a newer model like an AU or BA Falcon or even go for a completely different brand.
I'm taking the second option myself, time to move on from the EA and onto something better built. I'm currently saving up for a Subaru Liberty as they are reliable, large cabin space, looks good, pretty good power for a 4 banger especially if you chuck a couple of turbo's on and most importantly All Wheel Drive(front wheel drives are crap)
If you aren't happy with your E-Series there is no point moving onto another E-series, just asking for more troubles IMHO.
EA_Hooligan is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2005, 11:52 PM   #8
CruizinEB
you've got to remember that a EF-L is a compleatly different car to the EA, there not all the same.
Old 14-09-2005, 12:06 AM   #9
EFFalcon
Last warning
EFFalcon's Avatar
not pressing issues, yes they're roadworth and safety problems but its a matter of how you feel in regards to fixing this, generally going to be an expensive fix.
sounds like its low on fluid.. but its a 3 speed anyway so it'd be a cheap replacement (unless u gotta pay someone to replace it)
gearbox's = big money
new model would have 4 speed... and thus much nicer to drive
another expensive fix.. mroe common on ea's then later models.
might be headgasket.. or heater tap, or any number of places.
probably rocker cover, not a major deal.
could be fauly heater tap, where coolant may be leaking from.
heater box may be stuffed.. means dash out at worst
woulnd't even bother with that anymore.. just sounds crazy
most likely bushes, age does that.
IMO: upgrade.
too many expensive problems.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 14-09-2005, 12:22 AM   #10
niko
likes falcon's
niko's Avatar
ea=older than eb/ed etc...
eb/ed are at that age now that stuff starts letting go also...
www.carhubsales.com.au
Old 14-09-2005, 12:35 AM   #11
EA_Hooligan
Blown Head
Correct Niko.
No point upgrading to something thats going to show exact same signs in 12 months. IMHO he should seriously consider a newer model or a completely different brand.
Old 14-09-2005, 12:44 AM   #12
JADED6
V8 Ghia & BF2 XR6 + Wagon
JADED6's Avatar
Best thing i did was gte rid of my EA, took me 7 years as i kept fixing the problems (which wasn't a lot) & continued to drive it as it was very reliable but buying something newer was the way to go.
Bought an ED ghia and it is worlds ahead of the EA s-pac.
Completely up to you what you do.
EF or EL would be the way to go or if you can scrape together 10k an AU is the best choice.
JADED6 is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2005, 08:04 PM   #13
5speedeb
now with 3.73 lsd
try your luck at the auctions
plenty of bargins there
5speedeb is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2005, 12:02 AM   #14
brax
EL-Brax
seeing as i will be getting rid of the car, what do people think about buying an ex taxi with between 300,000kms and 500,000kms on the meter?
Old 19-09-2005, 09:18 AM   #15
INJECTED_250
Custom user title
EX cabs are stuffed.. mate... TOTAL PUSS BAGS.. i fix them.. and mate you end up spending loads on them.. full of dents, bog, holes, rattles, spew, vinal... Man you will 100 percent regret it... if i had a choice of an EL ex cab or an EA s pac with 180,000 on the clock id pic the EA 100 times over..
Once a cab always a cab.. and worst of all bright JEFFRO kennet yellow
Old 20-09-2005, 05:47 PM   #16
brax
EL-Brax
how about a '96+ EL falcon with about 250,000 on the clock?
also i'm a ford person, can't go another brand, toyota's are good reliable cars, however they only have the lexcen(falcodore size), which in my books is another holden in a different shell. I have looked at the camry, however the falcons are roomy and have (when treated well) enough power + they can tow a boat.
Old 20-09-2005, 06:02 PM   #17
RavenLS1
Another brand WTF!
RavenLS1 is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2005, 06:55 PM   #18
xr6 ausome
Low au
xr6 ausome's Avatar
the prices fords go for save some more cash get a newer car theres a eb xr6 at a yard for 3500 dont know what its like
But i wouldt bother save some more get a ef xr u can find a nice one around 8- 10
I sold my ed fairmont and got a au xr6 i loved my fairmont but the au is heaps better
99 au xr6 8 inch dvd pacemaker extractors sport exh lowered
MELBOURNE VICTORY/WEST COAST EAGLES :Reverend:
xr6 ausome is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2005, 07:14 PM   #19
RUKIDN
Missing the boost :(
i just went from a EA cfi, 300 thou+ km on the clock with problem after problem to my recent EB2 and it feels like a 'totally' different type of car! (alot to do with the 5speed tho) best thing i ever done i love it. so mate its up to you if you got the cash, a newer car may be the way to go, startin fresh but in the end every car will brake down sometime in its life! Good luck with it anyways mate _2:
BA XR6 Turbo
301rwkw mild tune
Modified by XR6Turbo Developments
RUKIDN is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2005, 08:41 PM   #20
db audio
Default time for change
yer mate definetly get an ed or an ef
i have an ea simply cos they r the worst model to buy cos lot of probs but thats cos i dun like it easy
aim for an ed fairmont ghia with sunroof thats what i would've chosen feully optioned n gotta luv that leather buckets not a fan of the ef/l the seats are weird lotta lumps n bumps (they call it lumbar support) i call it pain in the *** if i ever bought an ef/l i would put ea-ed seats in it hehehe
Old 21-09-2005, 06:57 PM   #21
tommo74
zx TT
The best thing ANYONE can do (unless they know substantial amounts of panel and paint ,mechanics,electrics etc is find the BEST example of any car.
I will agree though i would never seriously contemplate a series 1 ea or the 1st car of a shape change(hence i would rather go an el than an ef)
An rac check is mandatory when buying a car,also maybe (if from a car yard an extended warranty)
Noone said it was going to be cheap owning a car that you want to run like a well oiled machine!
i paid more than 7 grand for my '94 ed (with options) just this year
a rip off you might say?pah! it came with 3 years warranty,had "sensible"mods already done(genie extractors k&n panel filter etc) and less than 150 on the clock.
It doesnt use oil,water,blow smoke,no rust ANYWHERE no dents,interior even SMELLS new!
I included some more mods like edelbrock heads,intake,tb,mandrel 3 inch and leather seats all up for maybe just over 5 grand?hmmm i think!
Anyhow story goes for less than 13 grand i have a beautiful example of this car that drives down to the deli at 40 ks OR hits the highway producing more than 250 kw(flywheel)
Seriously it's best to find a spotless example of ANY car but you must maintain it if you want it to stay that way.
Or...you can keep buying thousand dollar cars that cos you 6 grand a year to keep fixing(not mods either!)I ,however got sick of doing that a long time ago...ahem!
good luck with your choice of vehicle!
Da LTD,3.9 ltr. 21.2 sec quarter mile.109 rwk
300zx Twin Turbo,Stillen intercoolers,boost controller,19 inch speedies,boost guage,dvd,mps,hands free phone,diamond black,leather interior.
12.8 quarter mile.243 rwk
tommo74 is offline   Reply With Quote Multi-Quote with this Post
