wont apply to many people but to the ones it does they will be greatfull :P
well after driving around with Xr lights on my car(s) for 2 and a half years i have finally figured out how to fix the high beam issue. what used to happen was you would flick on high beam on the stalk and the lows would go out. after looking at The NC Sportsman loom i just pulled out i noticed a diode? pluged into the wiring loom which is located under the coolant bottle, i have seen this plug heaps of times on my car with nothing plugged in there. i also noticed that the low beam relay on the NC was a Blue 5 pin one not a Grey 4 pin like normal. so i pluged both in and what do you know the high beam worked as normal! so all that is needed to fix the proble is the diode thing (has a brown top with yellow plug) and a 5 pin relay for the low beams. these can be found on all Fairlanes/LTD's as they are wired up like the XR lights are as they use the same globes. i will get a pic soon so people will know what to look for. |
windsor user
awesome, i knew it'd have to be something simple like that john.
just never had 2 cars to pull down and compare.... good find ![]() |
White Lightning
sweetas, awesome job john.
Driftin shopping trolleys
oooh but the cop style highbeam lights were cool :nutsycuck
#5 | |||
Low and Loud
Good to hear you fixed it Jonny Z
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
Hah no more falling for his impersonating a cop car trick either lol.
#7 | |||
Low and Loud
He Also wont be able to flash his lights at random people to get them to move.
Old news my friend. Or i just didn't tell anyone
02/90 EA II Fairmont
LoL I was just thinking that - "am I the only person who thought of a diode from the word go?"
211RWKW EA |
#10 | |||
Thanks for the tip! I wondered WTF was up with that when I converted my car, but never really bothered to look into it.
- John |
#12 | ||
The 'Stihl' Man
![]() Join Date: Jan 2005
oh awesome...yes pics of the wiring etc would be good, I hate electrics!
Yeah...no more tunnel vision!
Pods rule
wish i fixed it for you... then i would have done 3
EB xr6... Now sold ![]() Check out Build- http://www.fordforums.com.au/showthread.php?p=3083422&posted=1#post3083422 Current Rides- Xf ute, just installed ea wiring loom, dashboard, 3.9lt mpfi and a 5 speed with extractors and a 2/1-2 exhaust... its much better now! Check out Build- http://www.fordforums.com.au/showthread.php?t=11288204 -BF XR6... And its BLACK! |
#14 | ||
can someone post pics of diode and relay and where they go
#15 | ||
The 'Stihl' Man
well I changed the relay over but it still does it....
I rarely used high beams anyway, but ti would be nice if I didn't have to hold the stalk towards me when they are needed...lol
#16 | ||
any1???
#17 | ||
did you do the diode as well
#18 | ||
opps i forgot...here is the pic....
#19 | ||
thanks john xr6 your a champ
#20 | ||
The 'Stihl' Man
nah I didn't do the diode...probably why its like that then :/
Now I just have to find the bugger, because I doubt mine is going to be there...lol
#21 | ||
you have helped me out alot. cheers guys... i was changing relays like no tomorrow... didnt think to try 5 pin and the diode i would have had no bloody idea of...
will the diode be in a simlar spot on an EA? i hope so i dont want to go chasing for it |
#22 | ||
[EBGLT]
Not sure because EA's never came out iwth those quad lights however you may be lucky. You may find it or something similiar down behind the battery.
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
#23 | ||
your right, only ED XR's came with them. a few people have worked it out. the diode is in a simlar place but with the EA's you have to more the wire on the 5 pin relay from 87 and plut it to 30 and apparently that solves the issue. ill post later today and tell you if it works
#24 | ||
windsor user
if it were me, i'd go and look at how an NA Fairlanes wiring is..
the fairlanes have exactly the same setup as the XR's for the wiring to the globes..... if you can replicate the NA's setup you'll get it spot on |
#25 | ||
This thread is so old.
I got his XR front now and its not even wired up properly lol. Cop Spec is the best! |
#26 | ||
Jedaa
Has any body got a pic of loom & diode setup
Cheers David. |
