Old 17-09-2005, 12:38 PM   #1
JUZXR8
Hmmmmm
JUZXR8's Avatar
Default CFI Pod/Panel Filter
hey guys,
i want to put a pod or a panel filter onto my EA, but it is CFi, im not sure how to go about doing it, so any advice or pics u can offer would be great.
Thanks Alot,
Juz
Edit: Also i was wondering if an EL 4spd/3spd would go into my EA without any major hassles
JUZXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2005, 01:14 PM   #2
RUKIDN
Missing the boost :(
i wanted to do the same to my cfi when i had it but i didnt think it was possible. sorry im not much help but i may be wrong. if it helps a guy i know made a custom air box on his carby holden so he could chuck a pod filter on! mite be an option if your pretty keen to do it.. _2:
super6
BA XR6 Turbo
301rwkw mild tune
Modified by XR6Turbo Developments
RUKIDN is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2005, 09:55 PM   #3
Papa Smurf
Papa Smurf's Avatar
Originally Posted by Juz_Gremlin
hey guys,
Thanks Alot,
Juz
Juz, don't know about the filter? I have been told if you stuff around with them you will ruin fuel consumption?
As to the Motor? If your EA is a late one with 4 Speed auto? No worries but if not? you would be limited the the 3Speed auto? You would need to change the Computer on the left pillar and get wiring and change one of your Relays and also the Fuel Pump. BIG job but maybe worth it? It is in MY mind to do same : I have same as you, CFI but in an EB I.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2005, 10:02 PM   #4
EDXR8
EDXR8's Avatar
The main question is why, I highly doubt that many CFI engines would be putting out enough power to warrant the change. You might want to just get a decent filter for the current setup instead, Finerfilter do one for the CFI's. Another option would be to do what many are doing and convert the CFI over to MPEFI. The parts are failry easy and cheap to source from a wrecker and the power gains are good.
EDXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2005, 04:19 PM   #5
JUZXR8
Hmmmmm
JUZXR8's Avatar
where can i get ahold of a FinerFilter one?
Old 19-09-2005, 04:30 PM   #6
uglybob
XRWANAB
uglybob's Avatar
only the first of the EA's came with 3-speed autos - so anything from EB-EL will be fine! (assuming you currently have a 4-speed auto!)
'95 EF MkII Futura: http://www.cardomain.com/ride/980413/1
uglybob is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2005, 04:39 PM   #7
Grechie
Grechie's Avatar
if its CFI, get a unifilter or somethin for it (round air filter) that will help with the rev range
- Grechie
2015 FGX XR8 - 557rwkw on E85
KPM Street Fighter
PCMTec
Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19
Shockworks Coilovers
PITLANE AUTOMOTIVE & PERFORMANCE
Grechie is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2005, 04:50 PM   #8
JUZXR8
Hmmmmm
JUZXR8's Avatar
Yeah its the Dodgay half assed 4spd!!
Thanks alot for your help guys.
Juz
Old 19-09-2005, 06:53 PM   #9
Rowy,xr6
Pods rule
put the pod straight on, cut a hole in the bonnet put a scoop on
EB xr6... Now sold :
Check out Build- http://www.fordforums.com.au/showthread.php?p=3083422&posted=1#post3083422
Current Rides- Xf ute, just installed ea wiring loom, dashboard, 3.9lt mpfi and a 5 speed with extractors and a 2/1-2 exhaust... its much better now!
Check out Build- http://www.fordforums.com.au/showthread.php?t=11288204
-BF XR6... And its BLACK!
Rowy,xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2005, 10:19 PM   #10
JUZXR8
Hmmmmm
JUZXR8's Avatar
lol....is that legal?
Old 19-09-2005, 10:29 PM   #11
Rowy,xr6
Pods rule
if its small i guess
Old 20-09-2005, 02:00 AM   #12
EDXR8
EDXR8's Avatar
Easy just to order directly from them via their website (http://www.finerfilter.com.au/make.asp?make=FORD)
