Old 12-10-2005, 08:12 PM   #1
steweyau
Default DTE and antenna
A couple of quick questions
Can the DTE on an AUII be recalibrated??
How do you you get at the antenna/aerial on an AUII? I need to replace mine.
cheers
steweyau is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2005, 08:44 PM   #2
xr8ute
Back on the road
xr8ute's Avatar
Hmm...not sure what you mean exactly about recalibrating the DTE?
You can get to the aerial under the passenger side (front) wheel arch. Remove the plastic cover with the plastic plugs and metal tabs, then there will be a piece of foam that just pulls out, and there is the aerial ;)
Old 12-10-2005, 09:23 PM   #3
AUXRVIII
Changing your driving style is a form of DTE recalibration.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2005, 07:56 AM   #4
steweyau
Apologies, when DTE says 30 km to empty there is around 25 litres of fuel (gas) left according to the difference between the book (116 litres) and the pump (90 litres). My question is can this be re calibrated so it's 10 litres (or similar)
cheers
Old 13-10-2005, 09:38 AM   #5
xr8ute
Back on the road
xr8ute's Avatar
Is that factory LPG or Aftermarket?
The DTE is a calculated value based on fuel usage and tank size. It should technically be possible to change the value for the tank size. No idea who/how you would go about this though...Maybe AU Edit?
Old 13-10-2005, 10:04 AM   #6
steweyau
factory LPG (e-gas). I understand how the DTE works. It just seems to have a much smaller tank entered than the car actually has.
What is AU edit?? I'll start searching now.
cheers
steweyau
Old 14-10-2005, 10:09 PM   #7
Mechan1k
Mechan1k's Avatar
With an LPG tank ... you can only fill to 90% of the actual capacity ... it's a safety feature (gas expansion on hot days). You will only be able to fill to a maximum of 90L ... (although i managed 96L .. but that's a different story).
DTE still works as it is supposed to though ... but can be flakey though ... I don't trust it 100% ... I just go off how many KMs I have travelled.
Old 15-10-2005, 12:49 AM   #8
Walkinshaw
Two > One
Walkinshaw's Avatar
LPG by law is max 80% fill. 80L tank will fill to 64L etc
Old 15-10-2005, 06:00 AM   #9
Mechan1k
Mechan1k's Avatar
Sorry me wrong ... damn nightshifts screwing with my head ... I meant 90L for my ute (normally 110L) .. so 80% .. hee hee.
Old 16-10-2005, 09:10 AM   #10
GK
Walking with God
GK's Avatar
Did you see the story on A Current Affair or similar show? All about dodgy serv pump readings. A guy put 25 litres into an 18 litre tank and so on.
Stinking thieves!
GK
