I'm BOSS
Location: Where all Fast Fords are From, Northern Melb.
Hi,
First, up how much would a AU from a wreker cost?? Ball park figures. Where in melb does anyone know of a good wreker. Second, how hard is it to fit the AU motor into an EB/ED engine bay. Is it a drop in motor? What are some of the tings to look out for?? Cheers Guys
![]() ====Past Rides==== '04 BA XR6T 5spd T5: Nizpro Tuned, Valve springs, CIA, Injectors, 256RWKW '04 BA XR8 4spd BTR:Bluepower Tuned, BPR CAI, Big Boy exhaust, Hi Stall, 4.11s, 248RWKW PB:13.2@105mph '92 EB Fairmont GHIA 5.0LT 5spd T5:Stock with a cat back exhaust. '06 BF Fairlane GHIA 230Boss ZF 6spd: BPR CIA, cat back Exhaust. ====Present Ride==== '10 FPV GS Ute ZF 6spd:#108. With all the fruit. |
Adapt or perish...
Talk to OED666, he's just put an AU XR6 HP motor in his ED.
Carless
Once shy... twice bitten
And I'm in the process of doing it, I'll let you know how I go once I start.
The Devil crept into heaven... God overslept on the 7th... the New World Order was born on September 11. |
Former E-Series Member
I paid about $1300 for my motor, as new from an AU III, with 55,000 kms and all anciliaries. It is no harder than changing to a normal E series motor except that you need to cut the front K frame beam to solve a clearance issue (and weld a replacement), and change over to EA-ED engine mounts. Also, if you want to use an ED manifold as I do, there is extra stuffing around with XH belt & tensioner and A/C bracket mounts. Mine still isn't finished.
I'm BOSS
Would there be any benifit to just fit a latter model head from the AU to the ED block. I have read that from the EF onwards the crank was internally balanced which made the motor smoother. Would just changing the head not be worth an entire AU engine conversion??
they call me Tibbo
You'll be surprised what the head vs whole motor cost wise is.. The AU engines are super reliable and most wreckers have a surplus of them. I can get AU engines for $450 but a complete 2nd hand head is $330. For the extra $120 bucks I'll take the low kay bottom end as a bonus everytime
#7 | |||
I'm BOSS
For those that have done this conversion already or in the process, would you be able to post a pic of where the "k frame" needs to be moded??
#8 | |||
Shoot.
20V Turbo |
That is correct, I chose to cut it (just a bit beyond the width of the sump, because it doesn't go inwards like the EA-ED). The reason being, it is possible to weld an even stronger than stock beam in its place, whereas grinding the sump would still only just clear and you'd be slightly compromising the motor's rigidity.
Trouty, can you provide any pics of the K-Frame on your car, as I have said I'm in the process of putting an AU motor into my EB and would like to know as much as possible before I make a start. Also... If I use an AU alternator, I would be able to use the serpentine setup is that correct?
I'll try get some pics tonight. The AU motor should be fully compatible with EF onwards anciliaries (serpentine).
#12 | ||
slow & low EA Ghia
i didnt cut the k-frame i just grinded off the rib on the front of the sump, as some one said before, it would be easier, also it shouldnt loose rigidity, its only a casting of the sump, still gives enough clearance.
http://photobucket.com/albums/c392/papaghia/ here are some pics but dont have any of the sump, sorry Ehab
Ea Fairmont Ghia 1988 |
Yea, i recently put an AU XR6 motor in mine.. I didnt cut the k frame. Just ground away at the sunp. Its a relatively smooth change over. Cost me $900 with all accessories. Private Sale.
Wreckers in brissie have 35,000k motors for $650, and then you need accessories. They also include the manifold for $650. No price difference if you dont want it, only cuz they are like arseholes... They are everywhere.. THE ONLY THING TOO LOOK OUT FOR!!! the water pump outlet on the AU motor is smaller than EA-ED. You will find that you cant put your EA-ED bottom hose on the AU pump. I got a reducer made from stainless steel. Works a treat. You will also need thermofans if you keep the serpentine belt. If you keep the 3 belt setup, there is a ИИИИload of grinding to be done... 1 belt looks better... ![]()
Powered by Rollin Motorsport Turbo Barra ED 4L
#14 | ||
Thanks, for the extra info.
#15 | ||
Hmmm I didnt cut the k-frame or grind the sump on mine... plenty of clearence...
EA-D manifolds bolt straight on, EA-D engine mounts bolt straight on, EA-D water pump bolts on, EA-D accessories arent just a straight bolt up though... Aircon pump needs holes drilled and tapped in the block, Alt needs mounts changed a bit, and timing cover needs grinding so the adjusters can move. Would be much easier to convert to serpentine with an XH belt tensioner. |
#16 | |||
XRSVO
its very straight forward swap for an AU motor into ea-d my first ever eng change and not a hick up, car has put 45000kms since and hasnt stuffed up Ultra reliable and smooth compared to the old donks ![]() |
#17 | ||
Perana, if I choose to use the BBM, and all the AU stuff, I shoodn't need the XH tensioner should I?
#18 | ||
why can't you put an EB/ED sump on the AU motor instead of grinding stuff
#19 | ||
The sump is quite different I think. Anyway, here is the pic that was requested.
#20 | ||
Custom user title
NEd.. ill get back to u soon about the motor swap, just getting the cortina stuff sorted will be soon. Ned if u use the bbm u can use any EF/AU tensioner, u still need to run AU drive belt though. Make sure u get the bolts with the alternator. ALso may have to get either a pulley for your p/s pump or a second hand EF/au one (which i may have ). Also if u use the EB air bypass motor on the bbm manifold some bonnet clearance issuse arise.
Grinding the sump in an EA/ED is the easiest option in the 3 ive done they have never hit the front x member. Heres some photos of the sump mods... http://img219.imageshack.us/my.php?i...sc010619vd.jpg |
#21 | ||
Custom user title
#22 | ||
Thanks man, just wanna get it done ASAP, don't wanna leave stuff lying around in the backyard for ages, parents are killing me! I'll try and get my hands on a tensioner and pulley in the meantime, and if I can't then I'll let you know.
#23 | ||
sump can't be that different
#24 | ||
The Main caps being cross bolted on the AU would be part of it.. where they aren't on EA-L
#25 | ||
Custom user title
THe sump isnt all that differnt and its easy to make fit. U need the AU sump so u can bolt the AU alternator on.... No au sump no au alternator :>.. simple..
Why bugger around putting on an EB sump when an AU one fits in with 5 mins of grinding.... To make the eb sump fit u need to get the rear cap machined WAY TO MUCH WORK |
#26 | ||
I'm BOSS
1) I have noticed that most of you have used the EA-D inlet manifold and not the AU broadband manifold, why is this??
2) From what i have gathered the grinding off that rib on the fwd sump is the way to go. Quick and easy!! 3) Could someone explain why - if i was to buy a complete AU motor with all AU accessories ie; alt, comp, waterpump, pwr steer, AU inlet manifold & then modify the sump, put on the EA-D engine mounts, why the motor should not just drop in?? This seems easy enough to me..... please explain!!
#27 | ||
I'm doing exactly what you have said in number 3. I'll be running the serpentine belt setup, but you'll need an EL ECU to control the switching of the BBM and you'll also need to add thermo's. If you stay with the coil packs as the AU's had them, then you'll need to change looms as well I believe, however if you put a dizzy in its place your existing loom is fine.
Hope that helps, and anyone feel free to correct me if I'm wrong as I'm going through the same process myself.
#28 | ||
hmmm boost
yep im looking at either an AU or an EL engine into my ED pretty soon ,
so all this info is very helpful
EL TURBO GHIA GT3582R WOLF3D TUNED BY JEM |
#29 | |||
Jim.. |
#30 | |||
PM me if you want
If you lock the runners in long runner mode (for torque) you cant rev the motor above 3,800rpm so either switch them (and run ritch when they do switch) or leave them in short runner mode (same length as ea-ed inlet pipe) and there is no gain but it will look good. Get an EL ecu and put that in, a few wires have to changed, smartlock has to be added or bypassed is the only way to do it properly.
