Hey guys....
I've had this residue on my windows which i cannot remove for the life of me, and its really starting to irritate me. It looks like some kinda of spray has hit the windows and then dried on, leaving little droplet like splotches. Windex, car wash etc does nothing, tried metho and water mix too. Dude in supercheap reckoned its the sealant they apply at dealerships, which when they spray the cars, runs down onto the windows and then dries there. Today I tried heavy duty truck cleaner, which still hasn't done much, although removed some of it. Anyone else had the same problem and found a solution that works? (pardon the pun) Cheers, Jono |
it sounds like the same stuff that was on my instrument cluster, i couldn't get rid of it either
![]() Join Date: Jan 2005
Try Prepsol - it pretty much gets rid of anything. If that doesn't work, have you tried a blade/scraper?
prepsol hey, that's the stuff spray painters use as a last minute prep before spraying the cars isn't it
#5 | |||
If so try using a clay bar as an option ( take your time and be patient ) if little / no success here then try scrathx or a paint cleaner gently on the affected areas. If they are deep etched water marks you may need to have a Pro Detailer look at the glass for you. Moving forward to avoid this have handy a good quick detailer ( for paint ) and glass clnr with a few clean cloths and hit any drops of water that would otherwise sit on your car. Pete Last edited by DOC; 15-01-2006 at 09:33 PM. |
thanks guys, i'll work my way through your ideas till i find one that works. cheers!!
try thinners, just don't get it on your paint
buickman
Sounds as if your car has received some overspray from a backyarder or factory. The prepsol or claybar will do the trick thinners is to risky around paint & extreme care should be used if using thinners. Somtimes WD40 does the trick.
#9 | |||
excuse the ignorance...but what are clay bars and where can i purchase such fine items?
#11 | |||
buickman
#12 | ||
Big Block
Hi guys,
There is also a product called "Acid Rain Remover" which gets most things out. Try your local chemical maker or Glass Guy. |
Just slidin'
I had like a waxy type droplet effect all over the left quater panel of my camry. Nothing would get it off, so mum hit it with that white pasty type thing thats used for getting marks off walls, and a non scratch scourer, and it took her an hour, but it eventually came off.
MD Mondeo - For the family
#14 | ||
Fantastic Plastic
hi, i know this might sound silly, but i have had great success cleaning bad marks off like that with eith lemon or orange PEEL juice , squeeze a bit of the peel and collect the peels juice, not the juice from in the fruit ! - really works wonders ~ - be carefull - this stuff is flamable !
#15 | ||
haha completely by accident, i've discovered that a little bit of armoural in water actually removes the crap off the paintwork, but not the windows....so at least the paint is looking better!!
:P |
#16 | |||
Allso what is good to use on outside door rubbers that run allong the bottom of the window? mine is looking really bad kinda like mouldy crap but nothing will bring it back to look original. |
#17 | ||
Mr Polish
Clay - to remove environmental contaminants such as fallout, acid rain, sap etc and prepare the surface for polishing, glazing and or sealing (protective coating)
Door rubbers - clay first to make them smooth, then you will need a very strong oxidation remover Don't use prepsol for this Most rubber cleaners and protectants don't have the grunt to remove this and the black coating it leaves usually gets burnt off by the sun or simply fades
Detailology colour fx detail studio and R&D Lab SA's leader in auto detailing and paint treatments |
