Old 17-01-2006, 02:10 AM   #1
NC_Steve
She needs premium dude...
NC_Steve's Avatar
Default Hard Clutch Pedal
My clutch pedal is a bit on the hard side so im wondering if anything can be done to soften it? The clutch cable is fairly new and its a pretty standard duty clutch. On H series Holdens you can change the pivot point to give you more mechanical advantage but longer travel of the clutch pedal.. Do E series have anything like this?
Cheers.
NC_Steve is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 05:51 AM   #2
NZ
NZ's Avatar
A V8 clutch pedel might help
Old 17-01-2006, 05:55 PM   #3
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
Whats the differance Karl?
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 09:34 PM   #4
FTR888
heavy clutches are mad, ya could always lay some rubber, that gets the clutch slippin and therfor wearing it away, which will inturn give u alittle play at the beggining of the peddal, but it will also leave u with about 2mm off ya clutch plate, eheh, but tis fun.
FTR888 is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 10:12 PM   #5
NZ
NZ's Avatar
A shorter distance between the pivot and the pin the cable hooks to
Old 17-01-2006, 11:34 PM   #6
donno
donno's Avatar
There's a nut at the firewall you could have a play with to adjust the stroke. Mine was extremely stiff and didn't seem to engage properly. Spent an arvo stuffing around adjusting it then taking it for a spin until I got it how I wanted. She's a fair bit lighter now, but still by far the heaviest clutch I've ever used.
93 ED Futura, I6, KKK500r Turbo, Dev 5 head, custom Surecam, TKO500, Lokka. 250rwkw@4000rpm, 9psi, and lots of boost taper.
Comming soon: T04Z, plenum, TrueTrac.
donno is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2006, 12:24 AM   #7
XR Martin
XR Martin's Avatar
Hows your pedal box? Generally they get harder when pedal box is about to break.
2004 BA wagon RTV project.
Old 18-01-2006, 10:29 AM   #8
eav8
eav8's Avatar
convert it to hydraulic.....;)
project #1: Ea series1 Spac conversion to straight gas; 351Cleveland; T5; EB dash; sunroof and more as I get to them. :evilsasmo
Fully road legal and cruising in QLD!!
Happy dealings with; PROTD, !gn!t!on, Big_waity,Phongus
eav8 is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2006, 08:48 PM   #9
gthofan
Gunna girlie-man
gthofan's Avatar
he shouldnt have to convert it to anything, obviously there is a problem, does ur car slip out of reverse sometimes??? or crunch going into first when ur stopped
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2006, 10:35 PM   #10
NC_Steve
NC_Steve's Avatar
Nope. It goes into gear fine. And doesnt slip out of reverse. Just a heavy clutch pedal.
Old 19-01-2006, 12:08 AM   #11
mik
mik's Avatar
you could try a little wd 40 (spray can with squirt hose on the end great tool) on pedal bushes cable etc , a smear of graphite grease on pressure plate fingers can help too, a dab on the end of a screw driver through the fork hole if possible, can use a small mirror to aid in this
Old 26-08-2006, 03:38 PM   #12
falconkid
On here daily
Was this problem ever fixed, cos i have a very hard clutch pedal, i have just converted to manual, and i would like a lighter pedal
JIM
falconkid is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2006, 05:34 PM   #13
PetesEBII
Formerly PetesEB
Lets face it fellas.
No matter how perfect your clutch setup is, the e-series to a t5 are the stiffest pedals you can get.....well to my experience and i have driven some old school cars, i drove an 82 land cruiser and even that had a bettter clutch.
I have spent many arvos under the car and my clutch has come a long way from what it was but its still the stiffest i have driven.
:gren: Weapon of choice. :gren:
EB II, T5, Custom extractors, 2.5'' all the way thru, hardly legal tint, EL XR rims, on its balls, cold air intake + stainless heat shield. Custom boot garnish.
PetesEBII is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2006, 05:37 PM   #14
niko
likes falcon's
niko's Avatar
people have tried mine and swear it's as light as an excel, its an original ford XR6 spec clutch, i spent 2minutes adjusting the cable at the firewall and its great...
www.carhubsales.com.au
Old 26-08-2006, 05:38 PM   #15
niko
likes falcon's
niko's Avatar
Originally Posted by PetesEBII
82 land cruiser
will most likely have hydraulic setup :P
Old 26-08-2006, 05:44 PM   #16
PetesEBII
Formerly PetesEB
Nope, its got the frayed cable setup....
