Old 19-02-2006, 10:23 PM   #1
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
Default best performing FORD ecu for auto 4.0i?
i've got the opportunity to get an EDXR6 ecu for my ED, is it worth it?
would i be better off with an EF ecu?
recommendations and advice?
whats the best performing FORD ecu for auto 4.0i?
BA MK2 XR6T
ON_DUBS is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2006, 10:33 PM   #2
InitialD
Low and Loud
InitialD's Avatar
Unless you have 3:45 diff ratio the ED XR6 ecu will give you incorrect gear changes and kickdowns. Wont go that well basicly. But it does allow you to run a larger cam.
You only need a Tickford XR ECU if your going to have 3:45 or a lumpier cam. if your not going to have either for a long time I wouldnt bother. unless its dirt cheap
Old 19-02-2006, 10:42 PM   #3
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
the xr computer was a stash for later thing yes but i hadnt considered the diff ratio.
does that same theory apply to my current ecu if i changed the diff?
BA MK2 XR6T
Old 19-02-2006, 10:46 PM   #4
InitialD
Low and Loud
InitialD's Avatar
With EB2/ED yes it does
ECU's
GLi - 3:27(EB) 3:08 (ED)
Fairmont 3:27
Ghia 3:27
XR 3:45
Old 19-02-2006, 11:04 PM   #5
stockstandard
Forget EF/EL ecu's as well. The EF wont plug in, and the EL is tuned for a different manifold. XR ECU's are also tuned for different fuel pressure and will run leaner with stock fuel reg (not a bad thing). I personally wouldnt bother switching between the stock ecu's unless a better one fell in my lap.
Originally Posted by casper
