Old 20-02-2006, 10:50 PM   #1
blwneb
come join me
blwneb's Avatar
Default fitted different a/c condensor eb
Has anyone here ever fitted a different a/c condensor to eb, to stop heat probs onto radiator
ID RATHER BE BLOWN
blwneb is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2006, 05:58 PM   #2
blwneb
come join me
blwneb's Avatar
cmon pples are there any comments on this, i want to try and solve this problem i have, i believe the condesor is the cause, i have an eb 4l, with powerdyne blower on it, i cannot fit bigger radiator, i have replaced radiator with brand new one, i have 1 12inch fan on engine side(driverside) pulling air through radiator, as i cannot fit another fan on passenger side, i have another same fan on condenser side (passanger side, pushing air through, now the problem is, when the a/c is on and it is 30+ degrees outside, and your in stop start traficc the condensor gets so hot even with fans working it puts heat onto radiator, and as the water is not flowing enough it heats up, and by the time it gets into the engine it is like over 100 degrees, so the temp gauge rises to the last bar line and a/c shuts off, there must be a fix without removing a/c, any comments
ID RATHER BE BLOWN
Old 25-02-2006, 06:18 PM   #3
Racecraft
they call me Tibbo
Racecraft's Avatar
something else is wrong imho, i've had the condensors so full of oil and leaves (from leaking trans coolers) that no air could get thru it and although the A/C didnt get ice cold, the car didn't over heat.. What is the A/C like, cold, cool or ambient?
What is the water pump like? Do you run shrouds on your fans?
Old 25-02-2006, 06:30 PM   #4
blwneb
come join me
blwneb's Avatar
na i dont have shrouds, tthey are davies craig fans, a/c is cold, waterpump is 6months old and is genuine ford.
ID RATHER BE BLOWN
Old 25-02-2006, 06:32 PM   #5
Racecraft
they call me Tibbo
Racecraft's Avatar
so the air flowing thru is cold enough for the A/C to work but not to keep the water cool enough in the rad.. With the radiant heat of a car running hot you usually find the A/C is the first to suffer...
How long since the radiator had a flush or reco?
Old 25-02-2006, 06:50 PM   #6
blwneb
come join me
blwneb's Avatar
the radiator is 2months old, and it was flushed when i replaced it, it has to be the condesor, it is so hot, pushing hot air onto radiator, boiling the water.
ID RATHER BE BLOWN
Old 25-02-2006, 08:44 PM   #7
blwneb
come join me
blwneb's Avatar
thanks rollin, but i cant fit el thermos in, i have looked at that already, these are the 12inch 130wat fans. i might try to replace condesor, it is the original from 91, it does have a fair few fins which are bent, might be an isue but i wouldnt thing so.
ID RATHER BE BLOWN
Old 26-02-2006, 02:01 AM   #8
XR Martin
XR Martin's Avatar
Rollin is right, its definately related to the current fan setup you have.
2004 BA wagon RTV project.
Old 26-02-2006, 05:07 PM   #9
Rollin
Rollin's Avatar
why can you not fit half an EL fan setup on the drivers side? post a pic of your engine bay, showing the space you have between crank and radiator etc...
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2006, 07:24 PM   #10
blwneb
come join me
blwneb's Avatar
i will take a photo, the pulley is to close tp the radiator, i have already checked to see if i could fit el fans in.
ID RATHER BE BLOWN
Old 27-02-2006, 12:55 AM   #11
XR Martin
XR Martin's Avatar
Move the radiator forward?
Old 28-02-2006, 10:10 PM   #12
blwneb
come join me
blwneb's Avatar
cant do it checked already
ID RATHER BE BLOWN
