White Lightning
well im now limited to the daytime until i fix this so i thought i'd throw up my problem as someone else might be in the same boat or was once before.
basically i've never had highbeams as they never worked since i bought the car. i replaced the combo switch thing behind the steering wheel and tried swapping the relays around to no avail. so i just dealt with it. last night however i was coming home around dusk and something felt odd. then i realised i had no headlights either. dash lights were on, no probs there but the headlights wouldnt come on and i know the bulbs are good. anyone else seen this happen, esp on an ED XR6 with the quad setup? im hoping its just some relay or fusible link and not the loom or anything. |
Ute Forum Moderator
![]() Join Date: Dec 2004
Have you checked to see where the 12v is or isn't getting to?
which relays did you look at? obviously you checked the lights were plugged in correctly, and removed the bulbs and tested the out of the vehicle?
is the headlight switch on the dash plugged in correctly? its unlikely to be a wiring fault... |
when both mine went at the same time it had something to do with the wiring closest to the bulb area .. it had melted slightly but couldnt be seen easily..........
the wiring was cut, re-done and then I had headlights again ![]() hope that sort of makes sense!!!!!!!!!! |
White Lightning
well the wiring is exposed a bit on both headlights. not frayed or lacking thickness or anything. and theres nothing for it to short on. just checked the bulbs and 1 has blown, the other is fine.
Check the circuit breaker aswell dude, sorta had the same problem when I first got my car, the high beams would intermittantly not work and when they did they wouldn't stay on for more than 10sec and the circuit breaker would cut out and kill all the lights
Ed |
#7 | |||
Removed by laminge |
