Old 22-03-2006, 11:25 PM   #1
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
Default Pete's complete rebuild (hope it works).
hi all. well as the title says what i'm doing i thought i might share it with you seeing as you have helped me heaps so far.
i'll start with why i am doin it. well one loverly saturday afternoon i had to pick up my brother. i stopped at his place and left the car idleing while i went in. bout 1 minute later we came out and i took off. i was doing about 40km/h when i heard a noise at the front of the car and then the engine stopped. i didn't have a clue what had happened but when i popped the hood i saw that the rocker cover was smashed right at the front. we came to the conclusion that the timing chain must have snapped. anyway after i got it back home and got what was left of the rocker cover off i saw that the bolt that holds the cam sprocket to the cam had snapped! anyway i got the head off and sent it to a machine shop. EVERY VALVE was bent. pistons were all marked, chain guides smashed and sent all through the motor and so on. so i decided this is my chance to make it fast! and beat me mates 5.0l 5spd commodore.
so this is where i am at. i got the motor and auto out. block sent away to get all cleaned up and board out 20 thou. fully balanced bottom end. new acl race series oversized pistons. i am not sure about the cam yet probably go with a stage 4 crow with springs, vernier gear and chip torque chip. i'll have to send the head back to get it ported and all that. getting a CAI, thermo fans and new pacemaker extractors (the better ones). i have had the alternator and starter motor all cleaned up and i'm waiting on a new power steering pump.
the btr auto is going to get all the valve body cleaned out with a few mods so it will throw it into gear a bit harder. i'm getting a stall made for it to suit the cam (not sure how high yet), davies craige oil cooler and maybe rebuilt. i'm getting a LSD centre probably a 3.7:1 ratio.
the engine bay is being all cleaned up at the moment and getting ready to get sanded back. goin to paint it in the next few weeks, and all new water/oil pipes.
so it's a pretty big project and tell me if i'm dreaming but i'm aiming at the 170rwkw area. if anyone has any tips on what i should do or what parts to get it would be very much appreciated. hopefully i can get some pics up to show you all how it is now and how it turns out.
thanks heaps for the tips so far and the ones still to come.
pete
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 11:35 PM   #2
John_LS1
sounds interesting, pics would be good!
Old 22-03-2006, 11:37 PM   #3
sphell
sphell's Avatar
probably do a search that would be your best option as it's been covered heaps before. As for power, 170kw should be achieveable if you choose the right gear. There are a few people on the forums running just over 170rwkw. It's all in the head/cam combination. Working the bottom end won't give you any extra power, but it will give you reliability. People seem to get good results with JMM Dev 5 cam and head work.
Good to see you don't beat around the bush and you just get stuck straight into it.
Old 22-03-2006, 11:47 PM   #4
EB Pete
EB Pete's Avatar
i just tryed to upload some pics off the computer but it just sat there saying "uploading pics please wait" so i'll see what i can do
Old 22-03-2006, 11:52 PM   #5
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
Your gonna need some sort of ecu tuning. A unichip or chiptorque may do it, but 170rwkw would most probably need either a Microtech, wolf3d or even an MS2 to take over ignition and injectors.
Youd be needing another fuel pump and some bigger injectors(prob around 36lb)...
19lb injectors will only flow 36rwhp each so maxing out at about 216rwhp. However with a fuel reg others have got quite a bit more than this. But id go the ecu root if you could afford it.
Sounds great though mate, you must be excited. 170rwkw NA would be a weapon.
Cars:
- Ford Ranger Wildtrak
- XY GT Replica
- XB Coupe Project
BOOSTDEF is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 11:53 PM   #6
EB Pete
EB Pete's Avatar
i don't know about getting stuck into it. i just can't decide on the cam. i haven't got the block back yet so i'll have to make up me mind soon. yeah dev 5 seems good but i heard you can't get a stall made for the btr auto any higher than about 3000 grand
Old 23-03-2006, 12:07 AM   #7
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
3 grand stall will be plenty... tis all you will need for a road/strip car.
Cars:
- XY GT Replica
- XB Coupe Project
Old 23-03-2006, 12:25 AM   #8
OED666
OED666's Avatar
BOOSTDEF - about the injectors not flowing enough... i asked the same question to the guys at chiptorque, and they said mine are running fine... mine only putting out 162RWKW, but they said theres plenty of room left. I also have the standard fuel pressure reg...
i am interested to know who else has had a fuel problem when getting to 170+ RWKW... a figure i plan to get to in the near future...
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2006, 12:44 AM   #9
EDXR6T
good work ther mate
im going the N/A path ive desided to
hope it grab's the RWK's u want im hoping to get at that figure
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2006, 01:34 PM   #10
Brent79
Good god! Ummm... did u figure out if it was the chain that snapped first or the cam bolt? Thats scarey ИИИИ!! how many Kms was on the engine?? Should i go and replace my cam chain before it breaks too???
Brent
EB1 Falcon Wagon
3.9L Multipoint with 5 speed manual
Pacemaker extractors & 2.5" Redback exhaust
Tickford Head and Wade 1004 cam
HP4 Chiptorque chip and XH intake
1992 DC LTD
5LTR DUEL FUEL
Brent79 is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2006, 04:08 PM   #11
ea_boss_05
Brent
yes, why not get a hole rebuild just incase. it's not commen that a cam bolt snaps. most of the pressure is put on that little stub on the gear that holds the cam in place.
ea_boss_05 is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2006, 05:58 PM   #12
EB Pete
EB Pete's Avatar
it had 226 on the clock. it was only the bolt that snapped. the chain was still together. me pics are to large. how do i shrink there file size?
Old 23-03-2006, 07:03 PM   #13
BOOSTDEF
FPV GT Owner!!!
BOOSTDEF's Avatar
Yeh well i dont know how it works. Ive got 19lbs and a rising rate fuel reg and on 6psi boost mine was maxing out at 157rwkw, but had a very torquey curve. But yes, in theory going by what capacity the injectors are, 216rwhp (155rwkw) is what is supposedly the capacity.
Are you using a 5 speed? Tend to lose quite a few rwkw on the dyno with an auto so ive read??
Cars:
- XY GT Replica
- XB Coupe Project
Old 23-03-2006, 07:41 PM   #14
EB Pete
EB Pete's Avatar
i just got a second hand rocker setup to take a few bits off it and noticed that where the journals on the cam sit in it are rough as, compared to where the cam journals sit in the head. whys this?
Old 24-03-2006, 07:54 PM   #15
EB Pete
EB Pete's Avatar
well thanks to some people i can show you some pics.
i sanded most of the engine bay back today so i'm slowly getting there. still need some info from yas about what cam to get and what yas are using.thanks
Old 26-03-2006, 07:55 PM   #16
EB Pete
EB Pete's Avatar
hi all. i'm getting the block and bottom end back this week so i'll have to paint it all. anyone know what colour the block is? i think i'll go the crow stage 4, will the ms2 take care of it? and is it easy to tune if you know ИИИИ all about all that computer tuneing in cars? and how much would bigger injectors and fuel pump cost approx?
also what can i do to me auto? i'm getting all the valve body drilled out and was wondering what else can be done to make it a bit quicker? and what ratio diff centre should i run behind it? i was thinking about a 3.7:1.
another thing is what can i do to the intake manifold? 1st off all it's as dirty as in side so how would you clean that out? can you get it ported out and polished. i have also thought of a way to get some good cold air into it. is it illegal to cut into the bar across the front that the bonnet hooks into? i'll get some pics posted of the engine bay after it's all painted and the block. thanks for the help
pete
Old 26-03-2006, 10:15 PM   #17
OED666
OED666's Avatar
3.7:1's will be pretty good... better off the line, and good for highway... 3.89's are even better, but a touch too high revving on the highway... i loved having 3.89's with an auto... surprised many ppl from the lights...
get some carby cleaner clean the manifold. to keep it cleaner you could fit an oil catch can... something i planned to do, but i dont have enough room to fit the one i bought... something i might look into later on.
why do you need bigger injectors for fuel pump... i am not sure on the cost, but if you were looking into another fuel pump maybe a bosch 044...
Turbo Barra ED 4L
Old 27-03-2006, 06:05 PM   #18
EB Pete
EB Pete's Avatar
just in case i do need the bigger injectors and fuel pump. whats an oil catch can?
Old 27-03-2006, 06:58 PM   #19
vegabass
BASS ON BOARD!
vegabass's Avatar
what diff gears do you have now?
is it a LSD?
do you have a BBM? or the old style?
should think of new insulation in the engine bay before putting the engine back in!
Nothing interesting to put here.
vegabass is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2006, 07:37 PM   #20
EB Pete
EB Pete's Avatar
wouldn't have a clue what diff gears are in it now but it's an open diff. it sits at 1900 in overdrive at 100km/h. whats bbm? yeah how much is it for the insultation cause mines ИИИИed. should be getting the first under coat on thursday, still gotta get the grinder into the front bar that the bonnet hooks onto for me kisk *** cold air design.
Old 27-03-2006, 09:20 PM   #21
OED666
OED666's Avatar
you probably have 3.27 diff gears in it now. definitely open centre. BBM is Broadband Manifold. EF-AU manifold. BA and BF have it, but theres wont fit our motors...
BBM is meant to give more low down torque...
brand new diff gears installed are about $520, and another $550 for a re'coed LSD...
An oil catch can gets the blow by gases from the motor... thats why intake manifolds get dirty inside, as the gases mixed with fine amounts of oil get sucked back in the manifold. with an oil catch can, the oil gets caught, and only the gases go into the manifold...
Turbo Barra ED 4L
Old 27-03-2006, 09:31 PM   #22
EB Pete
EB Pete's Avatar
right. well i know ИИИИ all about cars! i can swap the centre over. it's pretty easy. anyway whats a shift kit do?
Old 27-03-2006, 10:46 PM   #23
vegabass
BASS ON BOARD!
vegabass's Avatar
Shift kit increases the line pressure to the box thus makeing box change harder.
should look at a BBM conversion....or not.
I bought so heat insulation the other day from coastal foam and rubber (one of my favorite shops) cost about $30 for meter square. It’s adhesive as well so its great to work with.
Old 28-03-2006, 05:46 PM   #24
EB Pete
EB Pete's Avatar
hi all. well i'm getting the block back friday and i need the head worked alot. i'm from toowoomba qld and can't find anyone to do it. does anyone know of a good place in brissy or the coast who knows what they are doing?
Old 28-03-2006, 05:52 PM   #25
vegabass
BASS ON BOARD!
vegabass's Avatar
I have spoken to Bryant Engineering about a full rebuild on my car and they give the impression that they have the experience to do it. I’m sure they have experience in race engines as well
They have flow benches and so forth so you should give them a buzz
Old 28-03-2006, 08:30 PM   #26
EB Pete
EB Pete's Avatar
think i found a place in brissy. does anyone know what C.F.M. stands for somthing to do with head flow i think. what do the auto shops need to fit a shift kit to me auto? can they do it with just the auto?
Old 28-03-2006, 11:32 PM   #27
OED666
OED666's Avatar
i am pretty sure CFM stands for Cubic Feet per Minute... It would be to do with flow rates...
i guess they would only need the box to shift kit it...
Turbo Barra ED 4L
Old 29-03-2006, 11:03 PM   #28
EB Pete
EB Pete's Avatar
thanks for the help so far guys. and those thermos fit perfectly paul, me mate is a holden man but he ИИИИin loved your car! said you look after it more than i do mine! anyway i'm getting a mold for 3 2' gauges and was wondering what gauges i should get. i'm thinking trans temp and maybe a air flow metre which i'll mount in the cai. what you guys think would be a good one to have?
Old 29-03-2006, 11:14 PM   #29
EF_Frmnt
EF_Frmnt's Avatar
oil temp possibly pressure as well if your car doesnt have all that in the dash
i would say Oil temperature.. fuel pressure and afm if thats what you want but it will really not help you in monitoring the engine
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2006, 09:16 AM   #30
vegabass
BASS ON BOARD!
vegabass's Avatar
Boost and NoS gauges.......
Im sure you can ge digital temp readings for CAI its a cheap kit from Jay Car
