Anyone got tips on tuning gas. I have an EL on duel fuel with a parnell system and it runs a little rough on gas. Can anyone remind me which knob does what and where to start.
Cheers and beers, Bob |
Get it done by a licenced gas tech. I doubt you would have the equipment to analyse the mixture anyway.
Which screw is for idling and which on for mixture?
Thankyou |
Location: Nowra (Southcoast) N.S.W. Beutiful beaches no smog & plenty of grog & yes that is my dog.
I would have it done by a pro as they
are so complex, the centre screw adjusts idle on gas carby & mixture screws are on gas converter u will not get it right without diagnostic equipment & have all sorts of problems as they can freeze up all the way up the line, very dangerous if u dont know what u are doing.
HOME BREW BEER SWINDLING PROFFESIONAL P-HEAD. TO MANY YEARS IN THE MAKING ![]() |
Custom user title
The screw to adjust the idle jet on a parnel converter is the top one on the converter in the middle plate. THere is only one screw on those converters u can adjust. THe viallie converters look the same but have a set idle jet with no adjustment.
U can adjust that screw without causing any damage as it doesnt affec any thing else through the rev range. They are normaly a fair way in. Mark the spot where it is now, and try a little in and then a little out, if it doesnt make a differnce, it may be other faults causing it to run rough. Leaking inlet manifold gaskets are a common fault for running bad on gas but fine on fuel. |
Thanks for the help. I have the idle screw for the converter on top on its own. What is the large screw on the hose going from the converter to intake for? I had a little fiddle with the large screw and it now idles heaps smoother. Thanks again!
