Old 01-04-2006, 09:29 AM   #1
tim2x
Default help installing a amp in my ef
hey guys, ive wired up the amp n sub,workin good
but .... howw do i pass the red wire (+) down from the engine bay to the car? is there a hole i can poke it thru or what not?
cheers guys.
tim2x is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2006, 11:01 AM   #2
EDXR6T
drill a 3 quarter hole thru the firewall lol
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2006, 11:45 AM   #3
ETH02
Force Fed Fun
ETH02's Avatar
Default Grommets
Check on the firewall ( Drivers side if I remember ) for a rubber grommet without anything going through it. Cut or drill a hole through it and it will seal the cable and protect it from rubbing on metal. You can then hide the wire under the door sill trims and carpet
Hope this helps
Steve
Steve
Shockwave BA MKII Typhoon :sm_headba
ETH02 is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2006, 11:56 AM   #4
lukey
www.lukehimself.net
lukey's Avatar
You can go through the wheel well if you want, saves drilling holes and rubbish.
Subaru Liberty MY04 4GEN Luxury
www.lukehimself.net
lukey is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2006, 12:15 PM   #5
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
i just drilled a hole neer the stering collem, put a plastic tube in it and ran the wire through then boged it with sclicon, works a treat
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2006, 12:23 PM   #6
tim2x
got it guys
now another problem - 4 sum reason it all doesnt want to work! the remote wire's in, the power led on the amps on .... but no fuses are blown.... so for some reason, the sub aint a pumpin :S
Old 01-04-2006, 02:30 PM   #7
vegabass
BASS ON BOARD!
vegabass's Avatar
Originally Posted by tim2x
got it guys
RCA connected?
Gain turned up?
Head unit levels up for sub?
theres heaps of reasons
what colour is the LED? red or green? is the colour saying safe mode?
Nothing interesting to put here.
vegabass is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2006, 01:06 AM   #8
daz82
In the family since 1996
daz82's Avatar
make sure everything is earthed properly, and all the cables leading out of the amp arent loose at all, i had similar problems once
daz82 is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2006, 11:48 PM   #9
crannersEL
crannersEL's Avatar
I used the hole mentioned above that is pluged by the small rubber plug, saves drilling holes through the fire wall.
If you need a hand getting it all working let me know
crannersEL is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2006, 01:17 AM   #10
sven
sven's Avatar
go the garden hose in the hole!! works a treat.
your amp should have an LED indicator. if that on power is fine. check all the connections if they are ok. must be the wiring to the sub
ED XR8
sven is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2006, 05:46 PM   #11
EFFANATIC
EFFANATIC's Avatar
Also ur remote wire hasnt been connected 2 the power has it. ! mistake i made and neva again lol
EFFANATIC is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2006, 05:53 PM   #12
-jjM-
-jjM-'s Avatar
mabye the LED is broken?
-jjM- is offline   Reply With Quote Multi-Quote with this Post
