FPV GT Owner!!!
Hi,
Was wondering what components id need to change in order to get softer suspension, but keep the low ride height. When flooring it, I want to lift the front quite a bit.. I mean, who deosnt. Also a traction issue too. Am i looking at softer rear springs of some sort or shockies? Cheers.
Cars: - Ford Ranger Wildtrak - XY GT Replica - XB Coupe Project |
windsor user
im not seeing the logic.... you wanna make your car handle worse by fitting soft springs, so you can look fooly sik when you tramp it?
FPV GT Owner!!!
No, isnt it common knowledge that softer springs will enhance traction, something a lot more important then looking "fully sick".
Will have close to 280rwkw, hard suspension didnt work with 150rwkw Edit: Dont give a stuff about handling. Straight line man here.
The 'Stihl' Man
![]() Join Date: Jan 2005
well Im doing it from the ride comfort VS looks scenario.
Im going to use a comfort short travel shock instead of the sports ryder or equivelent. I dont care for go kart handling unless its a sports car of some sort, id rather look low and have a plush (plus as I can get) ride than be bumping all over the place.
Former E-Series Member
I think the Whiteline kits are well regarded, also high end shocks like Koni and Bilstein. As for springs, I personally think King is only good for a budget set-up. I want to upgrade mine eventually.
well actually dude you need softer springs in the front with a high rebound ratio so they will give a lot more lift.. and hard springs in the back that will resist the rear sitting down. This is why dragracers run 90/10 and 10/90 shocks. The softer the springs you can put in the front the better, just dont expect them to be to low or you will chop your tyres out goin round corners..
oh and if you want straight line speed just disconnect your swaybar ;) |
Two > One
go for sof front rate springs and 90/10 front's and 10/90 rear shocks.
What Wheelspin?
easiest way would be to put au fairmont ghia springs in the front and remove sway bar from front as well. still will handle ok and when in a straight line, the front will raise and force traction to the back. is that what you after?
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
FPV GT Owner!!!
aahh sounds good. Thanks for the great responses.
So softer at the front, and harder at the back?? Thanks for that.
V8 Ute V8 Boat
i have a set of EB faormont springs you can have to cut for a very minimul price
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
FPV GT Owner!!!
Haha, i might of been interested but ive got plenty of "stock" springs here mate. Plus sending stock springs that far wouldnt be too economical. Thanks anyway though.
#12 | ||
hard rear suspension normally means more wheelspin doesn't it? I thought the rears couldn't be too hard, as less wheel spin is needed so you get more grip to give you the front going up?
