Old 09-04-2006, 02:31 PM   #1
Steve 64
Angry EF futura over revving
Good day, just bought an EF and it idles ok then just increases by its self then goes back. Could this be the idle control motor or something more serious. Cheers Steve
Steve 64 is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2006, 07:01 PM   #2
BABOSS
BABOSS's Avatar
Sounds like the ISC, can't be the timing because it's a coil pack. Try and pick up a ISC from your local wreckers rather than buying a new one just to be on the safe side. Also try adjusting the butterfly screw and see if that improves the idle. Could also be head gasket related, has happened to me before.
BABOSS is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2006, 08:09 PM   #3
Steve 64
Thanks, just wondering if there would be any other symptoms if head related. Cheers Steve
Old 09-04-2006, 11:53 PM   #4
2kool4u
Location: I live in my own little world, but it's alright, the people know me here
over revving is not a problem, it's a bonus :P
Man who walks through plane door sideways is going to Bangkok.
2kool4u is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2006, 11:55 PM   #5
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
How much of an increase in RPM is there? It could just be the ISC doing its job. They do get filled with grime, you can unbolt them and give it a good cleaning with carby cleaner.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2006, 05:40 PM   #6
Steve 64
Thanks Aaron, Its revving up to 1500-1700 revs and the back to about 600-700
I disconnected the idle speed control and it seemed fine (if anything to lower revs).
is there an ulternative to carby clean ie: Turps metho or anything the funds are very tight just got the car (and paying it off) once again thanks and have a good one!!!
Old 10-04-2006, 09:59 PM   #7
TwistedEL
TwistedEL's Avatar
You can use turps but carby cleaner is no more than $10 a can...
Old 11-04-2006, 07:53 PM   #8
heckaz performance
I heard somwhere else it can also be the steering sensor,
it's near the extractors in the engine bay.
Another time it was Exhaust sensor,
Other times it has been faulty ecu, idle control circuit.
Can be modded by fitting a plate under ICV with smaller holes.
heckaz performance is offline   Reply With Quote Multi-Quote with this Post
