Old 14-04-2006, 02:21 PM   #1
dnstocks
Default where is the transmission drain plug on EF 95 model
My hubbie wants to change the transmission oil on our old ef falcon 95 model futura wagon, and cannot find the drain plug
Can anyone help???
HS
dnstocks is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2006, 04:37 PM   #2
Holbrookau
OPT 20
Holbrookau's Avatar
It doesn't have one - you need to drop the pan to drain it.
Remove the rear and side bolts, lossen the front bolts and drain the oil while dropping the rear of the pan.
Remove the pan completely and give it a good clean inside. Check the filter is clean.
Reinstall the pan using a new gasket and refill (3.8 litres).
'94 EF GLI
Dash Mat
Color-coded Ashtray
Polished Wheel Nuts
Holbrookau is offline   Reply With Quote Multi-Quote with this Post
