anyone know the preasure for tightening an ea head.
FTF Club Moderator
PM a member called The Dok. He runs the headlight hospital and knows his stuff.
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
FTF Club Moderator
Sorry just realised that you wanted to tighten the head not headlight. That is me being tired, sorry about that.
Location: Under the bonnet, trying to keep as clean as above!
EBll series is: stage 1 40 Nm
: stage 2 90 deg clockwise not sure if that is the same as the EA |
#5 | |||
Genuine V8
EF-EL is the same. EA should be to.
Before FPV there was Tickford. Dont forget WINDSR plates for sale. (VIC) PM if interested. |
#6 | |||
Girrrrr!!!
Falcon EF XR6 in Heritage Green Heritage green, isn't that a fence paint? |
Thanks crew, I did the 40Nm then I took it to 100Nm, which was a bit more than 90 degrees. Its looking OK at the moment, fingers crossed.
did you tighten them from the middle out?
#9 | |||
meow
