Old 04-05-2006, 11:55 AM   #1
FS5
Default flo figures from old head
well i got the flow figures back from my original head i pulled off ,it flowed 351 hp at 500 thou lift and the exhaust flowed 72% of intake.the head i got ported flowed 368 hp at 500 thou.so i guess its not the head restricting it.
i'm going to get the cat checked soon.how much power do you think a dodgy cat would cause you to lose ?
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2006, 03:25 PM   #2
xr8ute
Back on the road
xr8ute's Avatar
Did they only measure the flow at .500"? You really need to know the curve at a few more points i.e. .100, .200, .300, .400...
What is the max lift of the inlet and exhaust valves of your current cam?
Just say max valve lift is .480", there is no value even knowing what the flow is at anything above that. The valve will spend very little of its open duration at max valve lift, which is why it is so important to know what the flow "curve" is like from .000" to max valve lift, say .480".
Old 04-05-2006, 05:19 PM   #3
jonbays
TL40 Wagon?
Too True even the Dev3HL HIGH LIFT only runs 0.525" max lift and I believe the Dev5 is only 0.530" so flow gains at 0.400 more useful in general terms.
Stock AU cam runs 0.476" lift on exhaust less on inlet I believe.
Old 04-05-2006, 05:34 PM   #4
jonbays
TL40 Wagon?
351hp at 0.500" is pretty damn good 72% isn't that bad either no real restriction here I think.
Not on a car thats running 140rwkw as it is anyway.
look at the flow from the original head 351HP or 276fwkw about 207RWKW!!
Even with the porting the potential increase is SFA 368HP about 275FWKW or 215RWKW.
No way a 140-160RWKW engine is going to gain much from porting then is it?
Old 04-05-2006, 06:45 PM   #5
FS5
heres the flow figures from both heads .its in corrected cfm with 28 inches of pressure or somthin.
original head
valve lift cfm
.100 55.5
.200 105.7
.300 160.3
.400 198.2
.500 228.0 351 bhp
.600 236.1
ported head
.100 54.3
.200 106.7
.300 165.3
.400 211.2
.500 239.7 368 bhp
.600 251.8
the ported head kicks but with the flow figures .just dosn't make the power for some reason.
from memory both the streetfighter and gnd cam had 480 thou valve lift going by our dodgy mearsurements anyhow.
thanks for the help guys
Old 04-05-2006, 08:19 PM   #6
jonbays
TL40 Wagon?
from the flow figures you would guess maybe a small gain in power of around 5% which i gues translates to a bit less than 10rwkw on a falcon six.
All the numbers seem surprisingly good to me.
Old 04-05-2006, 08:58 PM   #7
Stav
Smile
Stav's Avatar
Most au heads flow around 280 hp.The stock head is a monster mate. 351 hp is amazing.
Old 05-05-2006, 08:08 AM   #8
jonbays
TL40 Wagon?
Thats the sort of flow I would expect to see too. What head was this 94DT?
96AA WR etc the code on the front of the head?
Old 05-05-2006, 06:46 PM   #9
FS5
its a WR2A i did tidy it up bit before i got it flowed .just deburded it and that .not that it had much to tidy up.
Old 07-05-2006, 09:07 AM   #10
jonbays
TL40 Wagon?
WR2A is a just An AU standard head. By most accounts supposed to flow 280 to 300hp?
Old 07-05-2006, 10:43 AM   #11
xr8ute
Back on the road
xr8ute's Avatar
Did the exhaust side get modified as well, or just the intake?
Old 07-05-2006, 07:52 PM   #12
FS5
i tidy'd up both sides on the original head ,and the one i got ported had both intake and exhaust done
Old 08-05-2006, 01:18 PM   #13
jonbays
TL40 Wagon?
bloody good effort from a tidy up!
