AWD Assassin
What is going on here ??
Tried to record a program from my Toshiba DST Box in SD mode on my SONY DVD recorder and got the message ........"cannot record this signal"....... :nutsycuck Has anyone else copped this as well........Does it happen on Hard Disk Drive recorders as well. Whay has life gotten so complicated......... ![]()
Old RIDE 2006 BFGT Gone but not forgotten New RIDE 2018 AMG Mercedes A45 Angry AWD assassin
The following forum is pretty good for problems like that if no-one here can help
http://www.dtvforum.info/index.php?
Current: 2016 Camry 1966 Mustang Coupe Previous: 2011 SZ Territory Titanium 2008 Ford Edge AWD Limited Silhouette BF XR6, ZF Auto White EF GLi, XR look alike VH Commodore |
How have you connected them togther?
#4 | |||
Son of Wolverine
Usually get that message when you are trying to capture copyright material what is it you are trying to record.
Turbo's are great, but I'd rather be blown |
yes, if there is a Macrovision protection (Macrovision only protects on the analog out signal) if two digital devices are connected together the recording device will not attempt to record the signal. if the recording device is analog, it will attempt to record but you will get a bad recording
eg if you connect a DVD player in to a Mini DV camcorder, you will not be able to record the signal (from a movie) message appears "COPY INHIBIT" if you use composite video or S-video, will give u the same |
Gota be happy with a Hump
![]() Join Date: Dec 2004
The macrovision protection is encoded in the video channel.
Depending on how you have it connected there is ways of cleaning signals which overcome certain problems. Google is your friend. P.S. I am not suggesting that anyone should try and copy any copyrighted material.
![]() ![]() 12.756 @ 107.16..........1.915 60' Genuine Unopened Time ![]() ![]() |
AWD Assassin
Thanks all for your responses.
My current connections are thus : Toshiba HD set top box connected to Hitachi Plasma. STB is also connected to SONY DVD Recorder. STB output to DVD recorder Input. I can record most programs no problem. However, there are certain programs........FOOTY , some movies , docos etc, where it seems the signal is encoded and cannot be recorded......... Is this the case with a HARD DISK DRIVE recorder.........can you record any program on a HDD recorder or will the encoded signal also prevent recording on these devices as well. I imagine that you would still have issues recording the program from the HDD to DVD ????
