Bring on the lion...
I have ordered in a set of ultra lows. THey should be in by thursday, so will put them in thursday night. Will post pics up asap. How low does the ultras actually sit, also with a bodykit added, will it be TO low (ileagle)????
El falcon, 4.0, XR6 camshaft, pacemaker extractors, 2.5 inch exhaust with tri flow sports muffler, AU TE50 intake, with K&N panel filter, Advanti racing Stalker 17" rims, Sitting on Ultra Low King Springs, 'Gabriel' Ultras Lowered struts, NOW MANUAL, 3.45 LSD 9.694 @ 75.38 MPH at Mildura Drag Strip 1/8 Mile XC Falcon project car underway...... |
yes it will most likely lower your car to illegal heights
Awsome!!!! Thats what i wanted to hear LOL :evilking:
#4 | |||
![]() Join Date: Jan 2005
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
#5 | |||
the main issue is exhaust. if you can get that tucked up as high as possible then it pretty much all clears. |
Whats all this practibility iv been hearing about??? Iv neva heard the word before LOL
#7 | |||
FirstOnRaceDay
wat are Ultra Lows....? I know I'm stupid but i thought I would ask
A spring made by King Springs, it helps lower the car to a certain point, superlows are a bit higher than Ultra lows, and you can get Lows, Super lows, Ultra lows and I think you can get raised springs too :S
likes falcon's
yep; ultra high's haha
your better off looking at some pedders heavy duties for the rear though, much thicker coils equal a much better ride
www.carhubsales.com.au |
How are pedders spring rated? Or are they as you said, 'heavy duty, light duty' ect?
Too late to change now anyway, Iv ordered them LOL. They dont cost to much anyway, so if i want to, i can just buy some for the rear.
#12 | ||
likes falcon's
the actual coils are just thicker, this means they absorb some more of the *** bouncing that you get compared to superlows which are a thinner coil, im not saying there bad, but thats my next suspension mod when i get around to it.
atm im running king superlows and there pretty comfy but are slightly up in the air compared to the front
Yea, a mate has superlows, and i just dont think it sits low enough in the back. Thats why i went for ultra.
#14 | ||
the UL coils are thicker than the SL coils as i found out when i purchaced mine. rears anyway. if the coil is to thick it will be to harsh a ride.
#15 | ||
Yea true. You still want a but of give there.
#16 | ||
FirstOnRaceDay
Oh ok i have king springs I think they might be super lows
#17 | ||
V8 wannaabeee
just get ready and be in fit shape to change the springs to standard height once you get a canary
![]() i got superlows stiff suspension... on 17" rims.. and it's too low.. well i think it's because the muffler isn't tucked away, not sure if i can get the muffler any higher. |
#18 | ||
be hektick like me and go custom lol
#19 | ||
Fossil fuel consumer
![]() Join Date: Jul 2005
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
Ultralows are going to give you (in my opinion) a highly impractical ride height, unless everywhere you go has no inclines or declines, and there are no driveways in your town :P
It will sit extremely low, and yes will be illegal. Now while i don't care much for ride height illegality, give or take a few cms, yours will stick out like a sore thumb. The minimum distance required between the lowest point on your car (the lowest component hanging down under your car, be it cat or whatever it may be) is 100mm, 10 cm, FULLY LOADED. While most cops only care about height with only driver in it, that's the actual law. I am getting low's put in the front of my xr on thurs, and superlows on the rear. just putting lows on the front will drop it to within a bees d1ck of the legal limit.. then you have superlow, super-superlow, then ultralow, so yours is going to be severely low. If you just use it as a show car then go nuts, but for every day use i wouldn't recommend it. Either way do what you want ;p |
#20 | ||
The Guy You Love To Hate
Seriously i dont think he cares about legality lol.
Note the ULTRA in ultralows, it pretty much stands for ultra ridiculous low ride height. On oneredEDs car which has superlows he is about 7-8cm off the ground at lowest point with a few mods to make it driveable. 1. Some exhaust modification is a must. You will have to bring it closer to the body and possibly do an under the diff setup. Or dump it before teh diff which is cheap n easy. 2. Suspension work. Your diff will probably hit the body on hard bumps. With low ride hide you need stiff spring rate to stop body rubbing. I dont know what KINGs are rated to but i would recomend at least 10 or better 12kg/mm at the front and at least 8 at the rear. Take away 2 front those figures for a compliant ride (if thats possible!). You shocks will have a big impact on the ride and how low the car is. I would get some units with a high damper and rebound rating, falcons are heavy cars and need it. Go for Konis or something. Pedders is s h i t. Swaybars are essential esp to stop your front wheels from rubbing. You will need to run a bit of negative camber to help avoid scrapage. I would get the gaurds rolled while youre at it. The pinion angle looked to me to be less than ideal. I remember someone making up a set of custom upper control arms for the rear to fix this and control the new susp geometry better. And most importantly, youre car will look unreal with some dish. Get some deep dish rims!!!! Goddamn, thats a s h i t load of work right there! |
#21 | ||
I've got "Lows" in my EL, as it sits with a full tank of fuel and no passengers there is 13cm's clearence between the cat and the ground. When i get 5 people in the car it sits about 9m's off the ground and its lowest point which is illeagle.
Lows give the car that un-stock look but still alow the car to be driven without having to snake over speedhumps and even avoid some driveways. |
#22 | ||
Driftin shopping trolleys
super superlows=ultra lows... ultra lows is what people seem to call them but they are actually called super superlows.. Ive got them have fun with ur tailshaft bottoming out when you floor it.. When i drive normally i dont experience and problems with them and i live in a speed hump area.However, i have retained superlows in the front maybe thats why its a tad higher then usual.
VZ Calais 5.7ltr cammed, stalled, and the rest. 04 BA XR6T ute |
#23 | ||
When i got my 2.5 inch exhaust put on, i told them to tuck in as close to the body as possible, so thats done. Guards are already rolled. 'EDXR6T', i do have customs, LOL but though, why not hehehe. And all in all. If i dont like them, i know a few people who will buy them off me anyway, so its a win win situation. New shocks mite be on the list tho......
#24 | |||
Dish rims in my opinion only look good on big diameter, and thats not coming till later LOL.
#25 | ||
also, your tailshaft is going to make sweet love to the floor many times... especially launching, and mine used to hit on hard shifts...
keep an eye out for my coming thread about my tailshaft...
Powered by Rollin Motorsport Turbo Barra ED 4L
#26 | ||
Ouch... LOL The thing is my car is pretty slammed at the moment. I got proper springs for the fact that there isnt as much give.
#27 | ||
V8 wannaabeee
i do believe if you have standard SHOCKS in at the moment,,, you will need to purchase new shocks to suit ultra lows... i think the standard shocks will bottom out... thats what happend to my old car.. lol
#28 | ||
Oh, ummm..... cheers LOL. Na they are already on the list as well LOL.
#29 | |||
need more boost
T_Terror is correct in saying that if you tuck up the exhaust, drivability isnt bad. I have had to run a rather large amount negative camber on the front to clear the front quarters, and roll the guards also (but you've done that already). And also, get some fatarse swaybars too, the body roll if you corner very hard can lead to guard scrapage on the outer side of the car...
'94 ED Falcon GLi Suspended by: kings, koni, pedders Rolls on: 17" AJR Director's Stops due to: bendix, DBA Shifter connected to: T5 manual Power from: ??? Interior: velour and woodgrain Cost: stuff all :P |
#30 | ||
NOT A TOYOTA :/
Your car wont always look ridiculously dropped on ultra lows. I have them in my car and it still isn't low enough for what I would ultimately like.
06 Land Managed to remain in the v8 fraternity |
