Old 15-07-2006, 05:44 PM   #1
Orbit
Resident Nyctophobic!!
Orbit's Avatar
Default Electrical issues.
I've got a problem.
I can't turn the ute off if my foot is on the brake.
When i turn it off with my feet off all pedals...the brake lights stay on.
and when off if i put my foot on the break the dash lights, fuel and temp gauges spring to life
The break light switch is not faulty.
When i pulled out the tail light and brake light fuses the lights stayed on...
Any one got any ideas?
Orbit is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2006, 05:51 PM   #2
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
I Wouldn't have a clue sorry , sounds like its a mess ! .
But maybe start by checking all ya fuses with a multimeter and also make sure noting has melted/shorted across to another terminal behind the plastic fuse mounts / behind the fuse panel .
:eclipsee_
Old 15-07-2006, 06:23 PM   #3
superroo
You can't stop the signal
superroo's Avatar
Start by finding out what fuse there on. Pull one out, if lights don't go out, go to next fuse, and so on. If all come out, good luck to ya
Old 15-07-2006, 06:31 PM   #4
Orbit
Orbit's Avatar
_
Old 15-07-2006, 06:44 PM   #5
sednwol
sednwol's Avatar
Looks like a trip to the auto electrician, that weird indeed.
sednwol is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2006, 06:45 PM   #6
Orbit
Orbit's Avatar
i'm thinking shorted wire(s).
would a ford systems diagnostic pick something up?
Old 15-07-2006, 07:27 PM   #7
Orbit
Orbit's Avatar
Update.
disconnected the trailer plug....problem stopped. WTF!?!?!?!
can someone explain that to me
Old 15-07-2006, 07:49 PM   #8
Orbit
Orbit's Avatar
False alarm....but it appears if i hit the break pedal at just the rightmoment the whole lot will turn off.
Dodgey breaklight switch?
Old 15-07-2006, 08:43 PM   #9
Gilesie
You gotta pay to play
Gilesie's Avatar
sounds dangerously like to power circuits shorting.
Regards Gilesie
AU I Forte Wagon 4.0
Dodge D5N Twincab (Project)
2003 Mazda Bravo (work truck)
1979 F100 Ambo
Gilesie is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2006, 09:01 PM   #10
Orbit
Orbit's Avatar
any ideas on narrowing it down?
Old 15-07-2006, 09:44 PM   #11
My AU
Hi
Totally disconnect the trailer harness. Have a look inside the trailer harness connectors to see if they are shorting. Trailer harness are pretty clost to the top of the list as far as weird lighting faults are concerned.
My AU is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2006, 09:48 PM   #12
Orbit
Orbit's Avatar
did that...no luck
Old 15-07-2006, 09:57 PM   #13
Gilesie
Gilesie's Avatar
remove 1 fuse at a time.
I would start with the fuse for the brake lights to confirm or deny the issue
Regards Gilesie
1979 F100 Ambo
Old 15-07-2006, 09:58 PM   #14
My AU
Leave the trailer harness disconnected while carrying out what Gilesie suggested above. (Very good suggestion)
Old 15-07-2006, 10:00 PM   #15
XR6-VCT-2000
Fantastic Plastic
ok ... before you said you disconnected the plug for the trailer , then it was ok ./ then you said false alarm , but everything goes off if the brake pedal is pressed at the right time ? ..
Can you clear all this up a bit and tell us what you have connected/disconnected and whats exactelly happening / clearly , maybe able to help then.
cheers.
:eclipsee_
Old 15-07-2006, 10:08 PM   #16
Gilesie
Gilesie's Avatar
I dont know how I missed this
do you have any aftermarket electrical stuff installed?
was there any changes to your car when the problem started?
Regards Gilesie
1979 F100 Ambo
Old 15-07-2006, 10:19 PM   #17
Orbit
Orbit's Avatar
ok, to clear things up.
Turned ute off....break lights still on.
pulled the break light and tail light fuses. no joy.
pulled the taillight relay no joy.
put them all back in.
pulled the trailer and reversing light plugs...light went off after a bit.
put foot on break pedal..no cluster or tail lights.
started the ute put foot on break pedal break lights came on, turned off ute and knocked the break pedal everything turned off... tried again and accidentially knocked the break pedal..everything turned off.
tried a 3rd time this time making sure not to knock the break pedal, break lights stayed on...but cluster lights not on when i pushed the break pedal and ignition is off.
Old 15-07-2006, 10:21 PM   #18
Orbit
Orbit's Avatar
some aftermarket stuff for my driving lights...disconnected that circuit and no change.
the driving light circuit has been there for well over 6months, first problem today.
Old 15-07-2006, 10:25 PM   #19
Gilesie
Gilesie's Avatar
are the any wires rubbing on the brake pedal?
Regards Gilesie
1979 F100 Ambo
Old 15-07-2006, 10:26 PM   #20
Gilesie
Gilesie's Avatar
or in a position where the pedal will touch when pressed?
Regards Gilesie
1979 F100 Ambo
Old 15-07-2006, 10:28 PM   #21
HLC
Audi S3
auto electrician ftw.
Old 15-07-2006, 10:30 PM   #22
Orbit
Orbit's Avatar
ftw? please don't use sms lingo in my thread :
Old 15-07-2006, 10:34 PM   #23
Orbit
Orbit's Avatar
no wires touching anywhere that looks out of place
no rubing either
Old 15-07-2006, 10:38 PM   #24
Orbit
Orbit's Avatar
the ute had the tub sandblasted under warranty from ford....if they didn't remove teh tub from the tray (which i now have reason believe they didnt) would the dust be causing an issue somewhere? :
Old 15-07-2006, 10:44 PM   #25
Gilesie
Gilesie's Avatar
how long ago?
Regards Gilesie
1979 F100 Ambo
Old 15-07-2006, 10:45 PM   #26
Orbit
Orbit's Avatar
only picked it up today
Old 15-07-2006, 10:58 PM   #27
Gilesie
Gilesie's Avatar
so I assume that the problem was only noticed today after you picked it up and that there were no previous problems
Regards Gilesie
1979 F100 Ambo
Old 15-07-2006, 11:07 PM   #28
Orbit
Orbit's Avatar
correct
Old 15-07-2006, 11:12 PM   #29
Gilesie
Gilesie's Avatar
OK
In my opinion the repairer has caused the fault.
Is the dealer a Ford dealer or an independant?
Regards Gilesie
1979 F100 Ambo
Old 15-07-2006, 11:12 PM   #30
HLC
Audi S3
ftw = for the win. :
