Old 24-07-2006, 10:31 PM   #1
Ozfords
Girls! Drink! ****! ****!
Ozfords's Avatar
Default Inspiration - My New Rocker Cover
Hey gang, I just want to put in what I've gotten out of this forum, a post that I hope will inspire others.
If anyone in Sydney stayed indoors today I wouldn't blame them. In the Blue Mountains the weather was horrendous, cold, rainy and dreary. It felt a bit like the way Melbourne weather is described.
But I soildered on, in less the usual lighting I tended to the busted Rocker Cover gasket. I removed most of the attachments and swore my tits off at the rear pipe, which took longer than anticipated to remove. But I finally got it off, lay it on the tarp and took to it with a blade, wire brush and wax n grease remover. Painted it with 'Ford Blue' Engine Enamel replaced the gasket.
And viola!
My lovely hot little Rocker Cover. The blue turned out sensationally in the photos and is a bit darker in reality, but lighter than the Septone cap.
Thanks to others for posting up pics of their mods and personal touches. Some purists argue I'm a shoddy character that tears out pages from workshop manuals, borrows Gregory's guides and pesters those with knowledge. Sure I'm mechanically challenged, how the bloody hell I'm I to learn otherwise!! (For the record I do not tear pages out of Workshop manuals and I OWN my own EA workshop manual and 92-94 Gregory's manual.)
I hope this inspires someone, YOU CAN DO IT!
Automatic Driver and I'd be proud of that fact, only if I weren't so lazy.
1993 ED Fairmont Sedan - I6 - Colbalt Blue
- XH Snorkel
- Superlow Kings Springs and KYB Shocks
- Cross Drilled and Slotted DBA front Discs
- 18" pre-AU GT-P Alloy Wheels
- Ford Original Bootlid Spoiler
Ozfords is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 10:37 PM   #2
LukeyBAXR6
BA XR6
That looks very clean mate, good job.
Something i'm thinking about doing soon.. matter of finding some free time to do it.
None the less it looks great.
Phantom BA XR6 Falcon
LukeyBAXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 10:41 PM   #3
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
how did you get the strips and ford 4.0l parts back to standard? did you not paint them or did you sand the paint off afterwards?
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 10:49 PM   #4
Ozfords
Ozfords's Avatar
I sprayed it all, waited it to get a bit dry then used a turped up cloth and carefully wiped it off, with some force and done!
I thought about sanding it back, but I'm Generation Y, I want it NOW!!
- XH Snorkel
Old 24-07-2006, 11:48 PM   #5
snypereb
[EBGLT]
snypereb's Avatar
Ive got a red one of those mate what sort of paint did you use? Hope you used hi temp ause it will crap and peel after a while (3 months tops).
[EBGLT]
Old 25-07-2006, 08:24 AM   #6
Ozfords
Ozfords's Avatar
Apparently it is 'Engine Enamel', meant to withstand high temps, not peel and it should laugh in the face of heavy duty degreasers.
If it peels, well, I guess I get to choose a second colour, hmmm Tickford Red?
- XH Snorkel
Old 25-07-2006, 08:36 AM   #7
EA2BA
PM me if you want
EA2BA's Avatar
I found the trick to using ANY colour you want not just high-temp paint etc, you will still have to use duco paint though.
1. Bare metal sand fill and smooth the rocker cover.
2. Use white high-temp paint in lots of light coats to get a nice heat proof base.
3. Paint as usual primer sanded smooth then colour
4. Spray with high-temp clear enamel over the top
If you do it slow take your time and allow each coat to dry properly the paint retains its colour and does not crack or peel.
I have also used this technique for brake rotors as well, but for circuit/track work where red hot temps can be achieved on the rotors, I reccomend only all high-temp paints.
Old 25-07-2006, 08:55 AM   #8
BI6TIM
SnortPerformance.com
I have had my rocker cover painted in Polynesian Green for about a year now and had no problems with the heat. It was normal car paint not high temp. On top of that I didn't rub it back to perfection or spray high temp base coats or any of that. I haven't had a peeling or cracking problem, the rocker cover doesn't get that hot in my opinion.
I did however take the time to use sand paper to get the paint off the ridges and badges and then some super fine sand paper(think 2000 grit) and it came up polished. Looks awesome, unfortunatly I have no photo's of it.
BI6TIM is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 06:31 PM   #9
Damo
looks good mate, but god damn give that angine a degrease, looks like my EA. :P
Old 25-07-2006, 06:43 PM   #10
EFDream
XRR83D
EFDream's Avatar
Nice job......might have to grit my teeth and get out into the weather and do that one of these days......lol
2003 BA XR8 Falcon - Lightning Strike
Mods: 18" GT's (Aftermarket), BF GT front end(FibreSports), Tint, Premo Sound, Leather, CAI, DBA slotted,
2007 Suzuki Swift - Pearl Red
Povo Pack
EFDream is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 10:44 PM   #11
niko
likes falcon's
niko's Avatar
looks nice man, have you heard of degreaser ? lol
www.carhubsales.com.au
Old 25-07-2006, 11:04 PM   #12
snypereb
[EBGLT]
snypereb's Avatar
Degreaser and a pressure wash she will come up sweet!
[EBGLT]
Old 26-07-2006, 08:09 PM   #13
Ozfords
Ozfords's Avatar
Yes, yes, I'm waiting till its all dry then I'll give her a good degreasing and spraying. The cans on standby as we speak.
- XH Snorkel
Old 07-08-2006, 06:26 PM   #14
XPfalcon170
XPfalcon170's Avatar
That cover is looking very nice mate. Any other under bonnet enhancements on the horizon?
XPfalcon170 is offline   Reply With Quote Multi-Quote with this Post
