Old 30-07-2006, 07:55 PM   #1
cookie
BEER I NEED BEER
cookie's Avatar
Angry au2 stalls and nearly stalls when slowing down and stoping at lights etc.
hey guys just changed my au2 to manual and now when im driving it stalls and nearly stalls (100-200rpm) when im coming up to lights or traffic to stop when i push the clutch in and it goes to neautrl and down to idel rpm. it also happens if im cruising along and just put the clutch in or put it in nutreal and let it drop to idle revs. i changed to manual ecu and also changed the wirering to the manual harness not just wired into the auto one. any ideas guys its ****ing me off.
worked hard to get my new beast and i love it, it rocks. MYR16 the beast
cookie is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2006, 07:56 PM   #2
kenz
BOSS Pilot
kenz's Avatar
there has been a few guys here having the same problem of late including me. still not sure what mine was but i had the throttle body cleaned then reset the ecu and its been fine since
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2006, 08:41 PM   #3
cookie
BEER I NEED BEER
cookie's Avatar
how do you clean the throttle body. after you reset the ecu did you do any of the stuff they say to do with idleing in nutreal with a/c on off etc?
Old 30-07-2006, 08:58 PM   #4
bodes-sh
i always had this problem after disconnecting the battery in my manual ea...i know its not an au, but after a week or so it fixed itself and didnt do it anymore. i know its kinda annoying, but try the ecu reset procedure. then u will know if it works, otherwise ull just have to put up with it til it fixes itself up
Old 30-07-2006, 08:58 PM   #5
JC
JC's Avatar
That is the ECU reset.
2 things could be causing this:
1. Low base idle (adjust idle screw to set idle)
2. ISC valve not working - clean it out with Carby cleaner/WD40 etc.
Ford Performance Club ACT
JC is online now   Reply With Quote Multi-Quote with this Post
Old 30-07-2006, 09:14 PM   #6
cookie
BEER I NEED BEER
cookie's Avatar
i dont think its low idle cause after it nearly stalls it comes back up to normal idle revs. what is the isc and where exactly is it?
Old 30-07-2006, 10:15 PM   #7
JC
JC's Avatar
The ISC is the Idle Speed Control valve and it sits on the Throttle Body. It's job is to maintain an even idle, especiallyh when slowing down. Sounds like yours is stuck or at least not working properly. GK has done an article on how to clean it - would be worth doing (it costs nothing), even if it just eliminates this as the problem. Link follows:
http://www.fordforums.com.au/showpos...9&postcount=43
Old 31-07-2006, 02:53 PM   #8
cookie
BEER I NEED BEER
cookie's Avatar
cheers ill give that a go and see. has anyone else found this problem to be anything else just so i can check all avenues
Old 31-07-2006, 05:34 PM   #9
XITED_6
Was It Something I Said!
check out the isc as mentioned and oxygen sensor too...if not take it to ford and get all the codes etc recoded such as your map system etc & stuff.
let us know how u go
we live in a age where pizza gets to your door before the police
XITED_6 is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2006, 08:40 PM   #10
cookie
BEER I NEED BEER
cookie's Avatar
all fixed guys carby cleaned the throtle body and the isc and is good now thanks for all your help guys appreciated
