Grunt Files
i was on aufalcons.com earlier just having a look around because i am new to the site and i stumbled opon a read in articles about AU XR auto mode change instructions so i had a look and thought that it was a great idea so i went and tried it but it didnt work maby there was a step missed out or somthing can anyone shed some light on this situation??
![]() Join Date: Dec 2004
Just checked it.. its correct. Only variation is that the AU1's cluster doesnt show any confirmation.. but it does still work.
Grunt Files
i must be doing somthing wrong i couldnt get anything but econ mode on mine nomater witch one i tried. econ mode would be the factory setting wouldnt it??
no, factory set is adapt. If you reset the ECU thats what it will return to.
Grunt Files
oh ok i will keep trying when they say turn the ignition on that is the second bit just before you start the engine hey??
Yep, all the dash lights come on.
So its: Stop the vehicle, apply Park Brake and turn Ignition Off (completely) Apply Foot Brake and move gear selector to: 1 for Maximum Performance Mode 2 for Maximum Economy Mode 3 for Adaptive Shift Strategy Turn the ignition On (till the dash lights up) and wait for the air bag warning light to turn off Move the selector to "R" and wait for the segment on the cluster to confirm the mode selected: (Not sure if you will see this in XR's only for T series) PEF - Maximum Performance Mode ECO - Maximum Economy Mode ADP - Adaptive Shift Strategy Return gear selector to "P" and start the engine.
are you sure you havent had a replacement gearbox put in that doesnt have adaptive shift?
adaptive shift is ECU controlled. Any AU auto can do it if the ECU is an XR program.
Grunt Files
na its the factory box i got it into econ mode when doin that procedure but i did it for performance and now its stuck i will keep trying dam econ
#10 | |||
Audi S3
so if i swapped the ecu in mine to an XR6 HP ecu, i could get adaptive shift?
#12 | |||
im guessing only for auto's?
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
#14 | ||
I can't see how a Manual box can have its shift patterns controlled by a computer, so I'd say yes
#15 | |||
#16 | ||
Grunt Files
tried it over and over and no matter what i try i just keeps coming up with ecno
#17 | ||
Would this "Maximum Performace Mode" work on an standard AU Forte series 2 using the whole step by step procedure?
#18 | |||
Audi S3
so if you swapped your ECU for an XR6 HP ecu, then yeah you could have it.
#19 | ||
Fantastic Plastic
In the series 2 XR ( well in mine anyway ) , no matter what mode you select it will just flash 'econ' just to confirm a change has been made , no 'pwr' or 'adp' icon flashes when selecting these modes nor does an icon stays on the dash after selection, only when selecting economy the economy icon stay lit up on the dash/ there is no icon for adaptive or power mode .
cheers.
#20 | ||
Its probably just the T series that it shows the actual selected mode. If I remember right the AU2/3 flashes a different number of times to dictate what mode its in.
#21 | |||
Fantastic Plastic
#22 | ||
so, if it is true that this mode is on a XR ECU, how hard is it to swap them over? I have only ever done ecu swaps on an EA, can i just do a straight swap on my AU, or will it suff up the security and keys?
#23 | |||
Grunt Files
#24 | |||
Fantastic Plastic
#25 | ||
Grunt Files
ta bud
#26 | ||
XR8MAN
Here is the Adaptive mode change procedure for AU2 from the manual It just worked on mine a few minutes ago ADAPTIVE SHIFT STRATEGY (WHERE FITTED) 1-Stop the vehicle, apply Park Brake and turn Ignition Off position(0) 2-Apply the foot brake and move gear selector to: -1 for Maximum Performance Mode -2 for Maximum Economy Mode -3 for Adaptive Shift Mode 3-Turn the ignition Key to On (Position II) and wait for the air bag warning light to turn off 4-Move the selector to "R" (reverse)The ECON light will flash 3 times to indicate a successful mode change. 5-Return the gear selector to P (park) and start the engine Observe the operation of the ECON light to confirm the programming of the correct mode -One Flash after turning the key to On (Position II) - indicates Maximum Performance Mode is selected -Continuous illumination - indicates Maximum Economy Mode is selected -No illumination - indicates Adaptive Shift Mode is selected 6-Programmed modes will remain unless the EEC is reprogrammed as above or the vehicle battery power is removed |
#27 | ||
i notice in the specs of the BA autos, it says adaptive shift.
would it be the same thing or is it just refering to the manual shift part of the auto? |
#28 | |||
Fantastic Plastic
#29 | |||
DJR TM#54
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went. Now Zetec Powered. 1.6lt of madness. But the XR8 still remains ![]() |
#30 | |||
